Local Time 10:37 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Raspberry or Babana?
lew247
Posted: 02:17pm 27 Sep 2022
How about this
Esp32 with wifi and bluetooth the same pinout and size as the raspberry pico?
Could this be ported?
or are all Esp32's useless?
Posted: 04:05pm 27 Sep 2022
It could - but remember Peter has previously posted just how much work a "port" (re-write of all hardware-related parts) is.  (Months, or at least weeks, not days.  Using C.)
Edited 2022-09-28 02:06 by JohnS
Posted: 04:54pm 27 Sep 2022
  lew247 said  Esp32 with wifi and bluetooth the same pinout and size as the raspberry pico?
ESP32s are in no way useless. Annex Basic runs nicely on them. As far as porting goes (if I recall correctly), Peter said some years ago that the ESP32 was quite capable of running MMBasic, that he had ported the core functionality except for pin I/O (the hardest part of the job), and if someone wanted to undertake that I/O, he would provide the code he already had.
And as of now you can run simulations using them: Annex ESP32 web simulation
I'm not sure what great advantage there is to having the Pico pinout for the ESP32 (though I guess some of my PCBs could be used with them).
Edited 2022-09-28 02:55 by lizby
Posted: 05:16pm 27 Sep 2022
  Quote  Peter said some years ago that the ESP32 was quite capable of running MMBasic, that he had ported the core functionality except for pin I/O (the hardest part of the job), and if someone wanted to undertake that I/O, he would provide the code he already had.
Not quite, I said I would do the I/O but I needed someone to do the web I/F so, for example, you could edit from a browser. I had MMBasic up and running with SDcard and logging into wifi from what I remember. Seem to have lost both the code and IDE in a PC upgrade earlier this year though and Pico will be my last port as it gets boring after a time.
Posted: 08:39pm 27 Sep 2022
  matherp said
  Quote   it gets boring after a time.
Thanks for staying here so long, you made many people enthousiastic,. If you feel it is time for new adveentures, you should move on. But we will never forget what you have achieved.
Thank you....
PeteCotton
Posted: 11:24pm 27 Sep 2022
  matherp said  .... Pico will be my last port as it gets boring after a time.
I can't wait to see what your next big project is going to be! But yes, I would also like to thank you for what you and Geoff have created here. You have truly inspired me in many ways - from reliving my childhood programming in BASIC, to demonstrating what these chips are capable of.
This has obviously been a massive (heroic?) undertaking that most people would have given up on a long time ago. Thank you from the bottom of my heart.
Tinine
Posted: 05:59am 28 Sep 2022
That's like hearing your favourite band announcing their last and final tour
Posted: 06:09am 28 Sep 2022
Rumours of Peter's death seem greatly exaggerated, all he said was that he wasn't doing any more ports. He hasn't for example said that he is going to stop supporting his existing ports, join the Foreign Legion or give up electronics in favour of needlework .
Which isn't to say I don't echo the thanks of the other posters.
Posted: 07:10am 28 Sep 2022
Historically it's considered to be rather rude to make "Me too" posts, but sod it...
Me too.
