Local Time 13:36 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Z80 Simulator Running CP/M 2.2
GerryL
Posted: 03:56am 20 Sep 2022
Attached is a zip file of a Z80 Simulator for the CMM2 I have been playing around with that others of my vintage may find interesting.  This will also run CP/M 2.2 which was originally placed in the public domain in 2001 (reconfirmed and clarified in July 2022)
http://www.cpm.z80.de/license.html
Note this is a simulator and not an emulator so I have not covered off on some of the hardware and it will ONLY run the Zilog ‘documented’ instructions. Can be run with or without a mouse. The CP/M side is using the original Digital Research assembly files dated Jan and Feb of 1980.
To assemble the CP/M files and build some testers I wrote a Windows Console macro assembler that I have included. The macro assembler is based on Digital Research’s 1980 CP/M Macro Assembler Manual. This will assemble both 8080/85 and Z80 instruction mnemonics.
This simulator was written as a fun project so I’ll guarantee there will be glitches and the assembler may not understand every way you can write an assembly instruction (the Z80 has about 694 legitimate combinations of opcodes and operands so there is bound to be a screw up somewhere). Also, it is not lightning fast, it runs about an average of 2.5 times faster than a standard 4MHz Z80, or a bit over 1 microsecond per instruction (of course the times depend on the instruction type).
For anyone wanting to have a play around the zip file contains a number of guidance instructions and examples.  The analog clock example is a good demo of using an in-line repeat macro in the assembly code to do all the heavy lifting during assembly in generating the pixel location tables for the minute tick marks, second hand line, and minute and hour hand triangles. Note I have not checked if inputting or setting CMM2 pins actually works as the intent of the project was focused on the software side.
I have a lot of fond memories of the Z80 and CP/M 2.2, my first encounter was back in the early 1980’s when work purchased some Prolog boxes with a STD Bus cage, power supply and two 8 inch hard drives. We used a Z80 ‘Little Big Board’ (manufactured by Pulsar in Melbourne) running CP/M 2.2. This was used extensively to log strain gauges using a compiled Microsoft Basic program. We also used a CMOS Z80 board manufactured by JED Microprocessors in Melbourne for field work, logging a range of sensors and GPS.
Below is the image of the main display panel and below that is a snap-shot of a Tera Term screen of using the TBS Benchmark Basic tests in CP/M.  The first set of times is running directly in Microsoft MBASIC while the second set of times is from a compiled and linked version.
CMM2 Z80.zip
Gerry
Posted: 05:37am 20 Sep 2022
That is amazing. I myself was in the 6502 camp, but looking at this I can only congratulate you on such an achievement. That is stunning. Great work! All the more since it actually runs real code (cpm).
Edited 2022-09-20 15:38 by Volhout
Posted: 07:30am 20 Sep 2022
Truly beautiful! An excellent piece of work. :)
I'm going to have to have a play with this, that's a lovely simulator panel.
I first played with the Z80 about 43-odd years ago, on the Nascom-1 and I still have a soft spot for it. I also built a Vero-wrapped version of the MBC1 SBC with a couple of flash chips on it to act as disc drives (running CP/M, of course). I'm just considering getting a proper PCB and re-building it into a MBC2. Another ongoing project is a Nascom-4, which is actually a Nascom-2 plus add-ons but all running on a FPGA. It might even get a Gotek drive yet.
I saw a Z80 simulator running CP/M 2.2 or CP/M 3 on a ESP-32 with a SD card pretending to be a pile of disks the other day. I might try that too. :)
Edited 2022-09-20 17:42 by Mixtel90
Posted: 08:06am 20 Sep 2022
Brilliant bit of coding - many congratulations.
Posted: 08:12am 20 Sep 2022
Goodness me!!
Amazing.
(I used to write drivers for CP/M, MP/M, CP/M-86, MP/M-86, MS-DOS as well as UNIX etc.)
Posted: 09:10am 20 Sep 2022
Most impressive.
I didn't know you could call back from CSUBs into MMBasic - very interesting.
Good work,
William Leue
Posted: 11:43am 20 Sep 2022
My goodness! That is a brilliant piece of work!
-Bill
Posted: 12:01pm 20 Sep 2022
  GerryL said  I have a lot of fond memories of the Z80 and CP/M 2.2
Ditto. Terrific job. I started building a Z80 CP/M machine from boards in 1977, and got it working in 1979 (power supply was the big holdup). Did a lot of Z80 assembler coding.
But I'm spoiled now by MMBasic, and don't want to go back.
Posted: 12:19pm 20 Sep 2022
Me too. :)
Happy memories of using Zeap on the old Nascom-1 though. Seeing the OP's pictures suddenly brought back a lot of memories of register pairs and the alternate register set.
I'm going to have to get the Nascom-4 completed now. It has real chips for PIO, CTC and FDC.
Rickard5
Posted: 12:29pm 20 Sep 2022
OHH ME OHH MY, this is a pleasant morning, a step to unlocking Walnut Creek CP/M GOODNESS
twofingers
Posted: 01:05pm 20 Sep 2022
@Gerry
Sweet memories! Thanks!
Michael
Posted: 03:09pm 20 Sep 2022
this is really amazing work, well done! almost tempted to get a CMM2 just for this.
Hate to be Billy Boring... no R register?
also
Is the HALT="back to basic" functionality programmable? I would love to run some of my old stuff on here and we used the HALT signal as a single bit of I/O (well, O) as part of the memory swap hardware design. While I know the hardware would not be emulated it would still need to continue after the HALT (and subsequent INT to trigger the hardware re-configure). Small point, probably tweakable by yours truly.
Edited 2022-09-21 01:45 by CaptainBoing
Posted: 03:56pm 20 Sep 2022
Are you using dynamic flash, Cap'n?  ;)
Posted: 04:26pm 20 Sep 2022
LOL, I bought some off ebay... wasn't up to much.
The R register was often used to seed RNGs... just for compatibility's sake. As an aside, how short sighted of Zilog to make it only 7-bits.... why Zilog, Why? (and don't get me started on the 4-bit ALU!!!) I can only assume fab prices were hideous back in the 70s
Posted: 05:10pm 20 Sep 2022
They didn't need 8 bits for a DRAM refresh register at the time so they didn't provide them. :) Some later derivations of the Z80 did have 8-bit refresh.
The 4-bit ALU was very clever. The aim was to equal or better the 8080 in performance and by using 4-bits with pipelining they did it. There was also a separate 16-bit "ALU" that could just increment and decrement, but it was direct on the internal bus so very fast. That was used for all sorts of purposes.
GerryL
Posted: 01:44am 21 Sep 2022
thanks guys, appreciate the kind words.
Gerry
Quazee137
Posted: 06:29am 21 Sep 2022
Wonderful ! ! I LOVE my Z80 and CP/M and ZCP/M years.
Big THANKS, now I need to look through some boxes for my BIG Board and 8" drives.
Quazee137
LechU
Posted: 11:34am 21 Sep 2022
Is it possible to migrate this to MMBasic Windows/DOS?
Rickard5
Posted: 11:48am 21 Sep 2022
  Quazee137 said  Wonderful ! ! I LOVE my Z80 and CP/M and ZCP/M years.
Quazee137
OHH WOW you must be in Dallas to have a Big Board :), Jim Tanner has a Whole Stack of Blank unbuilt Big Boards :) I had a Big board back in the late 80's
TrevorC
Posted: 04:17pm 22 Sep 2022
Hi. I am having problems with running Z80CPM22.bas.
The OPTION to create the controls needs to be OPTION MAXCTRLS 120
Then when I select LOAD CP/M I get an error
Error in line 527 : IF without THEN
Can you help me with this error.
Thanks Trevor
