Local Time 14:42 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 16 MB Memory
georgestheking
Posted: 07:45pm 01 Sep 2022
Is the Picomite compatible with the chineese clone of Pi PICO having 16 MB of Memory ?
Best regards
Georges
Posted: 08:09pm 01 Sep 2022
It was posted support to 2MB.. honest, I did see that
Posted: 08:11pm 01 Sep 2022
This is somewhere else on this forum.. clones
DrifterNL
Posted: 08:21pm 01 Sep 2022
Here is a link to the clones thread -> https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15115
Floating Point Keeps Sinking Me!
Back To Integer So I Don't Get Injured.
Posted: 08:40pm 01 Sep 2022
The latest beta. b18, has been announced. One of the changes:
  Quote  Change to better support modules with >2Mb Flash chips
But I don't know any more than that.
Note that there are *no* boards with increased RAM as all that is on the RP2040 and it can't be expanded.
pwillard
Posted: 10:29pm 01 Sep 2022
Yes, I have one with 16MB (Pimoronoi Pico Lipo)
It worked properly 99% of the time... and in that other 1% of the time, it has a really slow response at the ">" prompt, related to the `NEW` command.  Pete just fixed it... so it's even better now.
Having 16MB is no longer a problem. Go for it.
Posted: 06:28am 02 Sep 2022
Peter didn't say anything about the other 14MB being usable, just that larger flash chips are better supported. That seems to be a timing rather than capacity issue (although they may be related). AFAIK MMBasic will only use 2MB of flash, no matter what size the chip is.
Tinine
Posted: 10:06am 02 Sep 2022
  pwillard said  Yes, I have one with 16MB (Pimoronoi Pico Lipo)
It appears from the benchmark that you also realised >10% performance boost, right?
I'll take that
Craig
Posted: 10:13am 02 Sep 2022
Just to be clear although you can use rp2040 modules with more than 2MB of flash you cannot and will never be able to access the extra flash from Basic.
Writing to flash requires all interrupts to be disable and all code to be running from RAM and this is incompatible with the way the PicoMite code works
