Local Time 15:47 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: Disable SD card removed message?
Posted: 08:33am 31 Aug 2022
Hi all.
Is there any way to disable the message that the PM throws on the screen when you remove the SD card?
VGA PicoMite, but probably also applies to the standard PM port, just that this will be reported on the console rather then the VGA screen.
Perhaps it is in the manual, but I have yet to find it...
Posted: 08:55am 31 Aug 2022
Only if you disable the console in which case you can use TEXT to the screen but not PRINT
