Forum Index : Microcontroller and PC projects : A simple Sudoku solver
This code is designed for the VGA Picomite but should run with minor changes on other platforms It will solve puzzles that do not need guesses. It could be built on to guess and then see if a guess yields a solution - feel free to add and post It contains a test puzzle which is displayed on startup. To run the solver with the test puzzle press the escape key to start the process. You will see the matrix of possible valid values in the right of the screen as the solver works. The solution is filled in on the left of the screen. There is a lot of cut/paste/modify in the code so if you see an error please report. To enter a new puzzle press any other character and then you can step through the puzzle entering the values. Use space for an unknown value. Once the last cell is entered the solver will start. Enjoy sudoku.zip Option base 1 Option explicit Option default integer CLS Dim rowb,colb,row,col dim s$ Dim a%(3,3,3,3,9) 'rowb, colb, row, col, not eliminated ' a possible value is if not seen in rowb=row, colb=col and not in any row/col Math set 1,a%() 'set all values as possible 'load sample grid Dim g%(3,3,3,3) Dim w=MM.Info(fontwidth) Dim h=MM.Info(fontheight) Dim i,j,found,eloop, solved 'replace this with a gui g%(1,1,1,1)=4 g%(1,1,3,1)=6 g%(1,2,2,2)=7 g%(1,2,3,3)=5 g%(1,3,1,1)=6 g%(1,3,2,2)=2 g%(1,3,3,2)=1 g%(2,1,1,2)=8 g%(2,1,2,1)=9 g%(2,1,3,1)=5 g%(2,2,2,1)=2 g%(2,2,3,3)=6 g%(2,3,1,3)=4 g%(2,3,2,3)=3 g%(2,3,3,2)=7 g%(3,1,1,2)=4 g%(3,1,2,2)=1 g%(3,1,3,3)=7 g%(3,2,1,1)=3 g%(3,2,2,2)=9 g%(3,3,1,3)=2 g%(3,3,3,3)=8 displaygrid do loop until inkey$="" do s$=inkey$ loop until s$<>"" if s$<>chr$(27) then For i=0 To 9 Line w,i*h*3,w*3*9+w,i*h*3,Choice(i Mod 3=0,2,1) Line w*i*3+w,0,w*i*3+w,h*3*9,Choice(i Mod 3=0,2,1) Next For rowb=1 To 3 For row=1 To 3 For colb=1 To 3 For col=1 To 3 print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)"-"; do i=asc(inkey$)-48 loop until (i>=1 and i<=9) or i=-16 if i>0 then print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)str$(i,1); else print @(w*2+((colb-1)*9+(col-1)*3)*w,h+((rowb-1)*9+(row-1)*3)*h)" "; endif g%(rowb,colb,row,col)=choice(i>0,i,0) next col next colb Next row next rowb displaygrid pause 1000 endif ' ' first pass look for cells that are now completely defined DO solved=1 do displaygrid setup possible eloop=1 For colb=1 To 3 For col=1 To 3 For rowb=1 To 3 For row=1 To 3 j=0 for i=1 to 9 If a%(rowb,colb,row,col,i) Then inc j found=i endif next i if j=1 then g%(rowb,colb,row,col)=found eloop=0 endif Next row next rowb next col next colb loop until eloop=1 scancol eloop if eloop=0 then solved=0 scanrow eloop if eloop=0 then solved=0 scanblock eloop if eloop=0 then solved=0 loop until solved=1 For colb=1 To 3 For col=1 To 3 For rowb=1 To 3 For row=1 To 3 if g%(rowb,colb,row,col)=0 then solved=0 Next row next rowb next col next colb if solved=0 then TEXT 50,400,"FAILED",,,3 ' end ' sub scancol(eloop) eloop=1 local colb,col,rowb,row,i,j, foundr, foundrb For colb=1 To 3 For col=1 To 3 for i=1 to 9 j=0 for rowb=1 to 3 for row = 1 to 3 if a%(rowb,colb,row,col,i) then inc j foundr=row foundrb=rowb endif next row next rowb if j=1 then g%(foundrb,colb,foundr,col)=i eloop=0 endif next i next col next colb end sub ' sub scanrow(eloop) eloop=1 local colb,col,rowb,row,i,j, foundc, foundcb For rowb=1 To 3 For row=1 To 3 for i=1 to 9 j=0 for colb=1 to 3 for col = 1 to 3 if a%(rowb,colb,row,col,i) then inc j foundc=col foundcb=colb endif next col next colb if j=1 then g%(rowb,foundcb,row,foundc)=i eloop=0 endif next i next row next rowb end sub ' sub scanblock(eloop) eloop=1 local colb,col,rowb,row,i,j, foundc, foundr For rowb=1 To 3 For colb=1 To 3 for i=1 to 9 j=0 for row=1 to 3 for col = 1 to 3 if a%(rowb,colb,row,col,i) then inc j foundc=col foundr=row endif next col next row if j=1 then g%(rowb,colb,foundr,foundc)=i eloop=0 endif next i next colb next rowb end sub ' sub displaygrid cls local colb,col,rowb,row,i,j For i=0 To 9 Line w,i*h*3,w*3*9+w,i*h*3,Choice(i Mod 3=0,2,1) Next Print "" ' For rowb=1 To 3 For row=1 To 3 For colb=1 To 3 For col=1 To 3 If g%(rowb,colb,row,col) Then Print Str$(g%(rowb,colb,row,col),3); Else Print " "; EndIf Next col Next colb Print "" Print "" Print "" Next row Next rowb ' For i=0 To 9 Line w*i*3+w,0,w*i*3+w,h*3*9,Choice(i Mod 3=0,2,1) Next end sub ' sub checkcols local colb,col,rowb,row,i,j For colb=1 To 3 For col=1 To 3 For rowb=1 To 3 For row=1 To 3 if g%(rowb,colb,row,col) then for i=1 to 3 for j=1 to 3 if NOT (i=rowb and j=row) then modcell(i,colb,j,col,g%(rowb,colb,row,col)) next j next i endif Next row next rowb next col next colb end sub ' sub checkrows local colb,col,rowb,row,i,j For rowb=1 To 3 For row=1 To 3 For colb=1 To 3 For col=1 To 3 if g%(rowb,colb,row,col) then for i=1 to 3 for j=1 to 3 if NOT (i=colb and j=col) then modcell(rowb,i,row,j,g%(rowb,colb,row,col)) next j next i endif Next col next colb next row next rowb end sub ' sub setup local colb,col,rowb,row,i,j For rowb=1 To 3 For row=1 To 3 For colb=1 To 3 For col=1 To 3 if g%(rowb,colb,row,col) then for i=1 to 3 for j=1 to 3 modcell(rowb,colb,i,j,g%(rowb,colb,row,col)) next j next i for i=1 to 9 If g%(rowb,colb,row,col) <>i Then modcell(rowb,colb,row,col,i) endif next i endif Next col Next colb Next row next rowb checkcols checkrows end sub ' sub modcell rowb,colb,row,col, veto a%(rowb,colb,row,col,veto) =0 end sub ' sub possible local colb,col,rowb,row,i,j,found for rowb=1 To 3 For row=1 To 3 For colb=1 To 3 For col=1 To 3 for i=1 to 9 if a%(rowb,colb,row,col,i) then print @(MM.HRES\2+((colb-1)*12+(col-1)*4+(i-1) mod 3)*w,((rowb-1)*12+(row-1)*4+(i-1)\3)*h+h\2)str$(i,1); found=1 else print @(MM.HRES\2+((colb-1)*12+(col-1)*4+(i-1) mod 3)*w,((rowb-1)*12+(row-1)*4+(i-1)\3)*h+h\2)" "; endif next i Next col Next colb Next row Next rowb if found then For i=0 To 9 Line MM.HRES\2+w*i*4-w\2,0,MM.HRES\2+w*i*4-w\2,h*3*12,Choice(i Mod 3=0,2,1) Line MM.HRES\2-w\2,i*h*4,MM.HRES\2-w\2+w*36,i*h*4,Choice(i Mod 3=0,2,1) Next i endif end sub Edited 2022-08-06 03:42 by matherp |
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
I had a dream that You put Your efforts into improving Your PLAY SOUND routine . my site |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6204 |
I thought about writing one myself, but never came to do it. It is one of those puzzles I like playing, although the 5* ones take some time. How did you come up with the idea to use a 3x3x3x3x9 matrix (the 3x3x3x3 I understand, but actualy 9 layers, one for each possible digit in each cell). You hear already, I havent given it sufficient time to think my own solver solution... Volhout PicomiteVGA PETSCII ROBOTS |
Hi Peter, Nice piece of work. I finally got to running it and it is nice to see the solver at work on the right hand side of the screen. Just great..!! Volhout PicomiteVGA PETSCII ROBOTS |
