OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056
Posted: 10:00pm 01 Aug 2022
Playing around with a BT keyboard and was wondering if I could connect to the PiPicoVGA. I understand that the HC06 initially connects at 9600 for pairing and I have set up com2 at 9600 but when I initiate pairing I cannot monitor any data. I would like to pair the two and then set option serial console to com2.
OA47
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418
Posted: 12:34am 02 Aug 2022
You will need to find some detailed specifications for the KB. What data format does it use? When it is used on a computer it is probably using a specific HID driver, so you may need to write one for the Pico that emulates a PS/2 KB or a serial console. (assuming that is possible).
Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10075
Posted: 01:24am 02 Aug 2022
It's a nice idea, but I think I have to side with phil99 on this one. It is unlikely that the protocol that the BT KB uses, is just plain ASCII serial that a module like the HC06 is designed to handle. The BT KB probably sends packet data at an unknown rate and protocol(past the BT link), that a driver is designed to interact with as Pill says. This simply will not be compatible with the HC06, so it will ignore any attempt to pair up with it.
My GUESS is that the HC06 is similar to the HC12, in that the HC06 is expecting to be paired up with other HC06's using the BT protocol, but anything OTHER then another HC06, will just be ignored. IE: The HC06's make use of the BT wireless protocol, but that does not mean they can pair with any other BT device other then that they were designed to pair up with - probably only another HC06 module.
Assuming you could even pair them up for the moment, as Phil hints at, you'd then need to know how to decode the protocol from the HC06, and somehow insert that into the PS/2 KB handler in the PicoMite firmware - not easy.....
Think of it like you are trying to pair a wee USB BT dongle to the PM, and expecting to be able to send WAV files to a BT speaker paired to the dongle. Easy with Windoze, MAC or Linux OS's, not really easy or practical with an MCU-based system.
Not saying it is IMPOSSIBLE, but it would be very tricky - even if you knew the wireless data protocol of the KB, there would be a lot of work involved.Smoke makes things work. When the smoke gets out, it stops!
