Local Time 19:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Windows 10 compatibility with old(er) software.
Bowden_P
Posted: 09:00pm 26 Jul 2022
I have recently updated my PC to a Win 10 64-bit machine, but would like to work on some old assembly code projects originally made on my old XP 32-bit wonder, which ran Microchip's old MPLAB v8.91 software.
I would very much like to use the old MPLAB software, rather than convert the projects to new new ones using the current MPLAB X v6.00 software.
Before seeking out the old MPLAB version for download, please can you advise me if this will be practical on my new machine. I gather there is a "compatibility mode" requirement here, but know nothing of its capabilities !
With regards, Paul.
Edited 2022-07-27 07:00 by Bowden_P
Nothing so constant as change.
toml_12953
Posted: 09:43pm 26 Jul 2022
  Bowden_P said  Hi,
With regards, Paul.
If you assemble 32-bit code, it should work. Win 10 64-bit and Win 11 (there is no 32-bit Win 11) won't run 16-bit software.
Posted: 09:45pm 26 Jul 2022
Haven't tried using it in anger recently but MPLAB 8.92 opens fine on W11. No special mode needed.
Edited 2022-07-27 07:45 by matherp
Bowden_P
Posted: 10:42pm 26 Jul 2022
Hi toml and Peter,
Thanks for your replies. Encouraged by your posts I have downloaded and successfully installed MPLAB v8.91, and loaded and assembled one of my simple old projects with almost no pain at all! That's amazing and not really what I was expecting!
The application went into the "(X86)" program files folder as expected - presumably for 32-bit programs. I have 2 drives on this machine, a C: - SSD, and a conventional D: - HDD. I got a moan from MPLAB because it couldn't find the old C: files to delete before assembly - I can live with that!
Now to try a more complex project - which draws code from my library.
With thanks, Paul.
