Local Time 20:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Astronomy
RicM
Posted: 10:36am 13 Jul 2022
Dear Members,
Dose any one know if the MOON.BAS lunar calendar with graphics and simple GUI will run on the CMM2
RicM
Martin H.
Posted: 03:36pm 13 Jul 2022
you mean this ?
http://www.fruitoftheshed.com/MMBasic.MOON-BAS-lunar-calendar-with-graphics-and-simple-GUI.ashx
I'm not the "MM Basic for  CMM2" expert though I just tried it in mm-basic for (windows).
1st Problem some Variables have the same Name but different Types (like m and m$)
2nd Problem, the Circle and Line (Box)  Commands uses differend Parameters..
since the program is not very long and very clear, it would work if you translate the original Syntax to your MMBasic version.
The easiest way to find out would be to test it
  Martin
Edited 2022-07-14 01:39 by Martin H.
'no comment
