Local Time 20:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Inverted Text
RicM
Posted: 02:23am 13 Jul 2022
Dear Readers,
Has anyone has a program to INVERT the text on the CMM2
RicM
Posted: 02:47am 13 Jul 2022
The 'Inverted text" option in MMBasic prints the text rotated 180 degrees.
If you want a mirror image with the text reading left to right, you could reverse your strings before printing.
Another option would be to use blit or sprites.
A third option would be to modify a font to invert the characters.
And there are probably other methods as well.
Depending on what you are trying to achieve, the first option (reverse a string then print inverted) is the simplest.
 CLS
 TEXT 400, 250, "Inverted Text", "LMI", 5
 TEXT 400, 350, reverse("Mirrored Text"), "LMI", 5
FUNCTION reverse(txt$) AS STRING
 LOCAL n, rev$
 FOR n = 1 TO LEN(txt$)
   rev$ = MID$(txt$,n,1) + rev$
 NEXT n
 reverse = rev$
END FUNCTION
edit again. Reversing the string then invert rotates each character so is not a true mirror.
IT depends on your requirements.
Edited 2022-07-13 13:00 by TassyJim
Posted: 04:06am 13 Jul 2022
Using BLIT
 CLS
 TEXT 200, 300, "Mirrored Text", "lt", 5,1,RGB(RED)
 BLIT READ #1,200,300,350,30
 BLIT WRITE #1,200,330,&B010
 DO:LOOP UNTIL INKEY$<>""
