Local Time 20:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Teraterm Numeric Keypad Fix
jwettroth
Posted: 12:58am 13 Jul 2022
I just discovered something that's been irking me for some time.  Maybe I'm the last to know but it was a revelation.  When using Teraterm, the numeric keypad including the extra cursor keys, numlock, home and end keys don't work right.  The most frustrating is numlock- it sends a command that closes the editor.  The default setting for the keyboard in Teraterm is a VT100 terminal.  If you go into the directory and find keyboard.cnf- change the following settings in the VT Section and voila.  It acts sensibly.
[VT numeric keypad]
Num0=off
Num1=off
Num2=off
Num3=off
Num4=off
Num5=off
Num6=off
Num7=off
Num8=off
Num9=off
NumMinus=off
NumComma=off
NumPeriod=off
NumEnter=off
PF1=off
PF2=off
PF3=off
PF4=off
I use excel a lot and use the numpad and cursor and its allways a muscle memory fight when I used the editor in Micromite.
There is a filed called PCKeybd101.cnf but I couldn't get it to work, the above worked for me.  Like most modern software, Teraterm is infinite redefinable, macroable, etc, etc.  This is all I needed.
John Wettroth
