Local Time 20:23 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ILI9481 IPS 480x320 display not recommended
Posted: 07:06am 09 Jul 2022
I've now received my display which I bought to support including a driver for BigMik but can't recommend this display for the following reasons
It's slow. Most display controllers are happy with 24MHz SPI. Mick's only works at 16MHz and mine only works at 12MHz. Others on the web have reported this as well.
RGB565 doesn't work which means the driver has to use RGB666 which uses three bytes per pixel rather than two - this increases access times by a further 50%
Can't use BLIT. Although the controller chip is supposed to allow reading the framebuffer there is no evidence of activity on the MISO pin from the display. As it happens the ILI481 driver will also initialise an ILI9341 so I can test that the framebuffer read primitives are correct and work but there is no activity on the ILI9481.
I suspect these displays have been built from a faulty batch of controller chips hence the comparatively low price.
Mick, I have fixed the portrait  etc. orientations and will include in the next beta
Edited 2022-07-09 17:07 by matherp
Posted: 08:32am 09 Jul 2022
Hi Peter,
That is disappointing about the speed, or lack thereof, Thank you for looking at it for me though, you did a wonderful job of getting it going, especially as you didn’t have a display at the time.
Thank you for fixing the driver orientations as well. I will just use them in places where I need the extra viewing angle and the speed is not a major issue.
Will the driver be set at 12MHz or can it run at 16 via an option? Either will be ok by me.
Take care,
panky
Posted: 10:01am 11 Jul 2022
Peter,
Does this caveat also apply to the 26 pin RPi 3.5" and 4" displays based on the ILI9481 (blue pcb and no SD card),
Cheers, Doug.
Posted: 11:25am 11 Jul 2022
  Quote  Does this caveat also apply to the 26 pin RPi 3.5" and 4" displays based on the ILI9481 (blue pcb and no SD card),
Those displays are wired as 16-bit parallel and have shift registers to mimic SPI. They don't have the same speed limitation but can't "BLIT" as the wiring doesn't support it. They use the "standard" ILI9341 driver not ILI9341IPS
Plasmamac
Posted: 06:07pm 12 Jul 2022
What is the best display for the pico ?
Plasma
Posted: 06:30pm 12 Jul 2022
  Quote  What is the best display for the pico ?
All the below support blit
With suitable adapter or wiring
ILI9488 with 680ohm resistor in MISO
ILI9341
Direct connect plug and play
https://www.waveshare.com/pico-restouch-lcd-2.8.htm
For high res and speed but high pin usage
Any SSD1963
Plasmamac
Posted: 07:35pm 12 Jul 2022
thx matherp
Plasma
Rickard5
Posted: 08:41pm 12 Jul 2022
I so love my Waveshare display, best Drunk buy ever ;) but I just found This Wave Share Display does anyone know if it will work as well as the Pimaroni one, this one has a bonus joystick :)
Posted: 09:12pm 12 Jul 2022
Looks like it probably will. The 240x240 ST7789 with a CS pin is supported by MMBasic.
Posted: 11:04pm 12 Jul 2022
Newbie. ili9341 is fast and touch is accurate an it reads sd card.
