Local Time 22:19 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Read buttons problem
coliscip
Posted: 05:53pm 04 Jul 2022
Hello!
I have connected 6 buttons from GP2 to gp6 to ground, without resistors, directly to ground
I've tried:
SetPin GP2, DIN, PULLUP
SetPin GP3, DIN, PULLUP
SetPin GP4, DIN, PULLUP
SetPin GP5, DIN, PULLUP
SetPin GP6, DIN, PULLUP
SetPin GP7, DIN, PULLUP
If Pin(GP2) = 1 Then Print "2"
If Pin(GP3) = 1 Then Print "3"
If Pin(GP4) = 1 Then Print "4"
If Pin(GP5) = 1 Then Print "5"
If Pin(GP6) = 1 Then Print "6"
If Pin(GP7) = 1 Then Print "7"
and
SetPin GP2, DIN
SetPin GP3, DIN
SetPin GP4, DIN
SetPin GP5, DIN
SetPin GP6, DIN
SetPin GP7, DIN
and it print
2
3
4
5
6
7
2
3
4
5
6
7
2
3
4
5
6
7
and so on...forever, till I stop it
In both variant of program (with or without "pullup" in defining of pins)
What do I wrong?
Thank you in advance!
coliscip
Posted: 05:57pm 04 Jul 2022
I forgot to mention... I do not press any key and it shows 2,3,4,5,6,7,2,3,4,5,6,7 ...
Quazee137
Posted: 06:00pm 04 Jul 2022
try
  If Pin(GPx) = 0 Then Print "x"
coliscip
Posted: 06:06pm 04 Jul 2022
YES!!!
tried:
If Pin(GP2) = 0 Then Print "2"
If Pin(GP3) = 0 Then Print "3"
If Pin(GP4) = 0 Then Print "4"
If Pin(GP5) = 0 Then Print "5"
If Pin(GP6) = 0 Then Print "6"
If Pin(GP7) = 0 Then Print "7"
And IT WORK!
Thank you Quazee137 !
coliscip
Posted: 06:09pm 04 Jul 2022
Now, please, how do I make to read just one time a button, even if i keep pressed a button?
Ciprian
Posted: 07:39pm 04 Jul 2022
Hi Ciprian,
In your test, you test for low level (key down) to print the text.
Next you should wait for key release (key up).
 Print "2"
 do: loop until pin(gp2)=1 'key up
end if
 Print "3"
 etc,,,
It gets more complex if you need to register multiple keys at the same time...
Edited 2022-07-05 05:40 by Volhout
Tinine
Posted: 08:31pm 04 Jul 2022
Something like this (unable to test, right now):
portmem% = 0
portread% = 0
do
 portread% = port(gp2,6)
 if portread% <> portmem% then
   if portread% and not 1 then print "2"
   if portread% and not 2 then print "3"
   if portread% and not 4 then print "4"
   if portread% and not 8 then print "5"
   if portread% and not 16 then print "6"
   if portread% and not 32 then print "7"
 end if
 portmem% = portread%
loop
Edited 2022-07-05 06:35 by Tinine
Posted: 08:59pm 04 Jul 2022
How about allocating interrupts to the pins and toggling a bit on just the falling edge?
Posted: 09:49pm 04 Jul 2022
With just switches, don't be surprised to get multiple apparent presses due to glitches.
If you do, you'll need hardware or software de-bounce.
Jo9hn
Tinine
Posted: 04:50am 05 Jul 2022
Debounce could be something like:
portread% = 0
scan_period% = 5
scan_count% = 0
settick scan_period%, scanin  'Read the port every 5ms
do
 if scan_count% > 7 then 'State of port hasn't changed for at least 8 scans
   scan_count%=0
 end if
loop
sub scanin
if scan_count% = 0 then
 inc scan_count%
elseif portread% <> port(gp2,6) then
 scan_count% = 0
else
 inc scan_count%
end if
end sub
Craig
Tinine
Posted: 05:45am 05 Jul 2022
Oops, I see a boo-boo:
portread% = 0
filtered% = 0
scan_period% = 5
scan_count% = 0
do
   if filtered% and not 1 then print "2"
   if filtered% and not 2 then print "3"
   if filtered% and not 4 then print "4"
   if filtered% and not 8 then print "5"
   if filtered% and not 16 then print "6"
   if filtered% and not 32 then print "7
   scan_count%=0
 end if
loop
sub scanin
 inc scan_count%
 scan_count% = 0
else
 inc scan_count%
 if scan_count% = 8 then
   filtered% = portread%
 end if
end if
end sub
