Local Time 23:16 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Raspberry Pi Pico W: Pico with WLAN, Geoff, Peter?;-)
atmega8
Posted: 04:11pm 30 Jun 2022
May be MMBASIC will get WLAN Support?
That would be very cool.
https://www.berrybase.de/detail/index/sArticle/10241
Edited 2022-07-01 02:12 by atmega8
Posted: 04:37pm 30 Jun 2022
Why not just use a device that's designed for WLAN, IoT or whatever? I'm sure there are plenty around. Why attempt to shoehorn something into a job that it was never designed to do? MMBasic has COM ports on all platforms that can talk to specialised chips. I think the idea is to write your own handlers, using those, to make those chips do what you want. :)
Posted: 05:40pm 30 Jun 2022
  atmega8 said  May be MMBASIC will get WLAN Support?
If you can suggest a sensible set of APIs (as few as make sense) that would be a help.
Michal
Posted: 06:12pm 30 Jun 2022
Maybe the http server could fit?
Michal
Posted: 06:23pm 30 Jun 2022
We've been through this before, haven't we? With the ESP8266 or something? No-one came up with any sensible commands for it. I think the problem is that there are too many ways to use these things - a library of standard routines makes more sense than building something into MMBasic as then you aren't having to be lumbered with firmware that most people will never use. After all, the AP+ commands have more variation than you would ever need.
Posted: 03:19am 02 Jul 2022
I may well be wrong, but I don't see Peter doing a special port for the Pico-W for the reasons that Mixtel90 has stated.  That, and there are ESP modules if you want WiFi, and HC05 modules if you want BT on your PicoMite based project.
As I say, I may be wrong - Peter has surprised us before, but......
Posted: 11:31am 02 Jul 2022
  Mixtel90 said  We've been through this before, haven't we? With the ESP8266 or something? No-one came up with any sensible commands for it.
Annex RDS Basic for the ESP8266 and ESP32 is chock-full of sensible commands. However, that's a long way from providing the details of the specification which Peter asked for (and no one provided, self included).
Posted: 12:19pm 02 Jul 2022
Annex is designed to run *on* ESP systems so it's commands are optimised for that purpose. It's a WI-FI control block in its own right.
MMBasic wants to see a modem. It needs a library of AT+ etc. commands to control the modem and make it do particular things. You *could* write all those Annex commands as that library if you really wanted to - that's basically what Annex is doing. It'll be doing it more efficiently, that's all. I doubt if the RF chip itself understands anything more than AT+ stuff.
Posted: 01:19pm 02 Jul 2022
  Mixtel90 said  MMBasic wants to see a modem.
I had thought that the point of Peter's having asked for someone to provide a specification was to allow MMBasic to do WIFI more natively, not to see it as a modem connection, which it already can do.
Posted: 03:41pm 02 Jul 2022
True - but at that stage there wasn't another way. You had a choice of a COM port or nothing. Now there's a possibility of an SPI interface - but only on one module. He'll not be interested in a different variation for each clone that has its own way to drive the RF chip. A COM port can be used by any 'Mite and to any module. The additional speed of SPI may not be that much of an advantage anyway - you'll probably still have to wait for responses from your module.
"Natively" depends on what you want to do - everyone will want commands to do *their* job. Peter wanted some low level commands that are versatile - that will do multiple jobs. I'm sure he'd still have some interest if that could be achieved - but it will have to be detailed. And remember that there's still a limit of some sort on the numbers of commands and functions.
