Local Time 22:20 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM default Drive
Chrisk
Posted: 05:46am 26 Jun 2022
Hi Guys
Currently when I connect my laptop to my CMM and enter via Tera Term I find that I am connected to the A: drive.
What is the correct instruction syntax to have this default to the B: drive (SD Card).
With the autorun file in B: the file is not found after a power fail.
I have no idea how this changed.
I tried the Drive instruction but it doesn't seem to work.
This below is attempting to change the default drive in a Explore 64
> DRIVE "B:"
Error : Unknown command
> ? MM.DRIVE
Error : MM.DRIVE already declared
Is this instruction the same for my Explore 64 and CMM.
Chrisk
Posted: 07:57am 26 Jun 2022
MM+ manual pages 6 & 19 for the Explore 64.
I think drive letters are not supported or needed as it can access only one card.
Though there is mention of limitations with exFAT causing paths to just show as A:/ so perhaps A:/ can be an optional prefix of paths.
Edited 2022-06-26 18:23 by phil99
Posted: 09:34am 26 Jun 2022
  Quote  Is this instruction the same for my Explore 64 and CMM.
No.  The Explore 64 does not have "drives".  So you cannot use "A:", DRIVE, etc.
On the original Colour Maximite you can use drives and the the default on power up should be "B:".
Do you have an SD card inserted?  Perhaps you have a hardware fault in the SD card connector or a faulty card.
You could try creating the file AUTORUN.BAS with a single line in it saying DRIVE "B:" and saving that file to drive "A:".  But that should not be necessary.
Chrisk
Posted: 07:53am 27 Jun 2022
Thanks Phil99 and Geoffg.
I suspect you might be right Geoff as I was updating the wiring and maybe something happened that I wasn't aware of.
I need to download this month's data at the end of the month and will check it out then.
Thankyou both for your quick replies.
Chrisk
