Forum Index : Microcontroller and PC projects : CMM2: Lines demo
| Lodovik Regular Member Joined: 17/05/2021 Location: CanadaPosts: 41 |
Here is a little screen saver-like program that displays differently colored lines objects that move around the screen, while changing form and color intensity. The longer are the lines, the darker they get. It was my backup project for this year MMBasic challenge. I stopped working on it when the frame rate began to drop below 15 as I added more features than the CMM2 could handle. The main obstacle was calculating the distance between all the points of each object as I needed it to modify the intensity. If you change resolution, it will adapt to match the objects size to the screen resolution. It works on MMBasic for Windows and is much faster there, even on a moderate PC. There's an Easter egg in it, too! LinesDemo.BAS.zip |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6206 |
Hi Lodovik, I get an error in line 93 "map not declared" Running MMB4W 5.07.03b4 Regards, Volhout PicomiteVGA PETSCII ROBOTS |
Hi Volhout, Looking at the error, MMB4W seems to think that the MAP command is a variable. I think it wasn't implemented yet on your beta version. It's working OK with MMBasic for Windows V5.07.03b10 here. Maybe you could try it with the latest beta? Also, my Windows setup is quite unusual: I use Windows 11 for ARM on a M1 Mac inside a Parallels Virtual machine. I thought that if it worked with my setup it should works pretty everywhere. It's giving me about 240fps (vs about 15fps on the CMM2) so graphics acceleration is enabled on my Win11 virtual machine (a thing I had problems with before). Edited 2022-06-27 01:39 by Lodovik |
