Local Time 23:25 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Call Subroutine with Missing Parameter - Bug?
vegipete
Posted: 04:07am 22 Jun 2022
Strange behaviour on my CMM2 (v5.0702)
The manual says "missing values will be assumed to be either zero or an empty string."
> list
option default integer
i = 0
testsub
testsub 1
testsub:testsub 2
testsub :testsub 3
print "Number of calls:" i
end
sub testsub n
  print "parameter =" n
  i = i + 1
end sub
> run
parameter = 0
parameter = 1
parameter = 2
parameter = 0
parameter = 3
Number of calls: 5
Note the missing result before the call with the parameter set to 2. If a colon appears immediately after the subroutine name, the subroutine doesn't appear to be called at all.
Posted: 04:22am 22 Jun 2022
  Quote   If a colon appears immediately after the subroutine name, the subroutine doesn't appear to be called at all.
With the semicolon as the last character of the first 'word' on a line,
the interpreter assumes you are creating a line label.
vegipete
Posted: 04:53am 22 Jun 2022
  TassyJim said  the interpreter assumes you are creating a line label.
Makes sense, I suppose. Made for puzzling program behaviour until I figured out the 'work-a-round' of adding a space, or a new line.
From the manual "A variable name or a label must not be the same as a function" but says nothing about a subroutine.
