Local Time 02:05 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Output PWM
mikedownunder
Posted: 10:16am 18 May 2022
Hi All
I have one of these https://www.soberton.com/wt-1201/  that I want to drive with a Micromite using PWM command on Pin 6 of a 32MX170F256B. Pin 6 is PWM 1C, and the syntax is PWM, freq, 1A, 1B, 1C. I'm not really sure what this means. All I Want is to hear a short alarm from this Buzzer when called in a SUB.
All help greatly appreciated.
Mike
Posted: 11:39am 18 May 2022
You would be better off moving the device to pin 4 which is PWM 1A.  The way the PWM works you must also use pin 4 (PWM 1A) and pin 5 (PWM 1B) as PWM outputs if you are using PWM 1C.
If you do move it to pin 4 the command would be PWM 2500,50 and you will be able to use pins 5 and 6 for other duties.
You will also need a buffer transistor to drive that device as it has a very low impedance.  Have you thought of using an easier to use device like this (no PWM required).
Edited 2022-05-18 21:42 by Geoffg
mikedownunder
Posted: 12:54am 19 May 2022
Thanks Geoff
I can understand now.
I had the other type on hand in my odds box. Guess I'll have to go shopping to Altronics again. Trouble is I always end getting other stuff!! Oh well such is life.
Thanks again
Mike
