circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 310
Posted: 08:38pm 17 May 2022
Is it possible to attach a keyboard to this board? It seems that the required keyboard connection to GP8 and GP9 is not available. Is it possible to use the keyboard on any other pins?
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12083
Posted: 09:32pm 17 May 2022
This board is incompatible with PS2 keyboard use. For console use SPI displays are too slow so the KBD pins were chosen to be compatible with the SSD1963 displays. You can of course use the KBD with displays where you have more flexibility in connection like the ILI9481 and ILI9341 Edited 2022-05-18 17:25 by matherp
