Forum Index : Microcontroller and PC projects : PicoMite SD card
| Kalevi Newbie Joined: 28/09/2021 Location: AustraliaPosts: 9 |
Firmware loaded OK. MMBasic running OK. GUI calbrate OK. Picomite demo OK. Typing in word 'files' brings up message: 'SD card not found'. I have checked for hardware problems (connections, shorts, wrong earths) none found. The card checks OK in another machine. Mauri |
What does OPTION LIST say ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
As thwill has hinted at, you have to tell MMBASIC that there is an SD card connected. By default, MMBASIC will assume that it does NOT have an SD card. From the PicoMite manual, page 38: "SD Card Support" Smoke makes things work. When the smoke gets out, it stops! |
The OPTIONs are as suggested by Admin Group except for SDCard: OPTION SDCARD GP21. In Silicon Chip design GP21 the pin used for SD Card. PG22 is used for Infrared input. |
If, as implied, you are using the SC design then most of us have no access to the design which make it difficult to help. Normally, if the connections and options are correct, issues with SD are solved with improved power supply and/or decoupling the SD supply from the main supply as in my designs. |
