Local Time 03:53 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Rotary Encoders
Rickard5
Posted: 07:45am 25 Apr 2022
Has anyone played with Rotary encoders on the PicoMite? I was digging though the parts and found 2 that I want to work in to a project and I really need help figuring out how to make them work. Also has anyone ever messed with the encoders out of mice? that would be cool, I got a ton of sacrificial mice I could gut for sensors and microswitches :)
Tinine
Posted: 07:57am 25 Apr 2022
I use rotary encoders all the time but for motor speed/position control. One needs to decode the quadrature of the 90deg out-of-phase signals of the channels A and B.
This sounds like a good task for the Pico's PIO if anyone has figured-out how to use it.
I use other processors that read constantly without the need for interrupts.
Craig
Tinine
Posted: 08:05am 25 Apr 2022
This is a method that I came up with. Non-conventional but I wanted speed and I haven't seen anything that can beat this. I submit this because it is probably the best explanation of how these things work.
It's in PropBasic, ignore the "wrlong" because that is a Parallax Propeller thing.
'Decide where to start
If Chan_A = 1 And
   Chan_B = 1 Then
   Goto A1B1
Endif
If Chan_A = 0 And
   Chan_B = 0 Then
   Goto A0B0
Endif
If Chan_A = 1 And
   Chan_B = 0 Then
   Goto A1B0
Endif
If Chan_A = 0 And
   Chan_B = 1 Then
   Goto A0B1
Endif
'Keep hopping between these labels
A1B1:
If Chan_A = 0 Then
  Dec Counter
  Wrlong HubCTR,Counter
  Goto A0B1
Elseif Chan_B = 0 Then
  Inc Counter
  Goto A1B0
Endif
Goto A1B1
A0B0:
If Chan_A = 1 Then
  Dec Counter
  Goto A1B0
Elseif Chan_B = 1 Then
  Inc Counter
  Goto A0B1
Endif
Goto A0B0
A1B0:
If Chan_A = 0 Then
  Inc Counter
  Goto A0B0
  Dec Counter
  Goto A1B1
Endif
Goto A1B0
A0B1:
If Chan_A = 1 Then
  Inc Counter
  Goto A1B1
  Dec Counter
  Goto A0B0
Endif
Goto A0B1
End
Craig
Posted: 08:17am 25 Apr 2022
See here for my bounce immune rotary encoder I/F code. Haven't tested on recent releases but should work with minimum change
You shouldn't need a PIO for a rotary encoder. MMBasic is almost certainly plenty fast enough if you are turning one by hand. The fastest way, I think, is to feed the inputs into interrupt pins.
Tinine
Posted: 10:03am 25 Apr 2022
  Mixtel90 said  You shouldn't need a PIO for a rotary encoder. MMBasic is almost certainly plenty fast enough if you are turning one by hand. The fastest way, I think, is to feed the inputs into interrupt pins.
Spoil-sport
I'd really like to see a real-world example of PIO in use
Craig
Posted: 11:15am 25 Apr 2022
Look at the PicoMite VGA then. :)
2nd CPU feeds a PIO with video data, PIO produces the syncs etc.
Posted: 12:01pm 25 Apr 2022
  Rickard5 said  Has anyone played with Rotary encoders on the PicoMite?
Right here  using Peter's code. Rotary encoder is the black module, top middle.
I used it to navigate a menu on the little LCD, and to select menu options.
Edited 2022-04-25 22:02 by lizby
circuit
Posted: 07:43am 27 Apr 2022
  Rickard5 said  Has anyone played with Rotary encoders on the PicoMite? I was digging though the parts and found 2 that I want to work in to a project and I really need help figuring out how to make them work.
See the section "Rotary Encoders" - Page 56 of Geoff's excellent manual "Getting Started with the Micromite" that is supplied in the documentation section of the standard Micromite download.  That is the simplest and quickest way to start with these devices.
Rickard5
Posted: 11:58pm 27 Apr 2022
That's it , the deeper I get in to this the more like I feel like a way late to the party, but going back to Micromite Manual is a Great reference
DaveJacko
Posted: 09:11pm 28 Apr 2022
I bought one of these a few years ago,
and they're a nice tactile thing to play with.
The difference between Gray code and Quadrature is important to know!
I've attached my code, which the reader might agree, is impressively concise.
However, it also demonstrates really bad programming style..
I can not understand how it works, and I coded it !
'test prog for useful little rotary encoder
'quite clever use of array, bin$, int
'one detent gives 2 increments -why?
' 12 apr 2020 Dave J
Option autorun on
Option default integer
Dim g(15)=(0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0)
'gray code 0  1 2 3 4 5 6  7  8 9 0 1 2 3  4 5
SetPin 3,din
SetPin 2,din
SetTick 1000,dspac
mnlp:
ni=Pin(3)+Pin(2)*2
If ni=oi Then GoTo mnlp
gi=(oi<<2)+ni
Print Bin$(oi,2),Bin$(ni,2),Bin$(gi,4)
oi=ni
Print g(gi)
Pause 10
ac=ac+g(gi)
GoTo mnlp
Sub dspac
Print ,ac
Try swapping 2 and 3 over
