Local Time 06:22 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Extracting information from a .WAV file
OA47
Posted: 07:27am 11 Apr 2022
Does anyone have an idea on how I could extract the Artist name and other info from a WAV file before it is played on a mite. I noticed that the information is apparent on the first line when you open the file with NOTEPAD but not sure how I would extract it.
OA47
Amnesie
Posted: 09:13am 11 Apr 2022
This is a really good question and it would be interesting to exctract them somehow for some kind of audioplayer application.
OA47
Posted: 09:37am 11 Apr 2022
I was wondering if I read the file in for the first 100 odd bytes and gather the text. It seems that the initial string is "RIFFžQÖWAVELISTÐ   INFOIART" Artist name is followed by "INAM" which is followed by Track title proceeds "IRPD" which is the Album name and "IGNR" followed by the Genres.
OA47
jirsoft
Posted: 09:51am 11 Apr 2022
WAV wiki
Jiri
OA47
Posted: 05:09am 12 Apr 2022
Amnesie, if you are interesred here is what I cam up with:
'Program to extract .wav file info and play
Option EXPLICIT
Dim I,PNTR1,PNTR2,PNTR3,PNTR4,PNTR5
Dim INFO$ LENGTH 140
Dim A$ LENGTH 1
Dim DLIM$, ARTIST$, TRACK$, ALBUM$, GENRES$, FILENAME$
Input "ENTER THE WAV FILE PATH AND NAME";FILENAME$
Open FILENAME$ For INPUT As #1
INFO$= Input$(140, #1)
Close #1
Print
Print
For I= 1 To Len(INFO$)
DLIM$=Mid$(INFO$,I,3)
If DLIM$="INF" Then PNTR1=I              'FOUND FIRST POINTER IN STRING
If DLIM$="INA" Then                      '2ND POINTER FOLLOWS ARTIST NAME
 PNTR2=I
 ARTIST$=Mid$(INFO$,PNTR1+8,PNTR2-PNTR1-8)
 Print "ARTIST ";ARTIST$
If DLIM$="IPR" Then                      '3RD POINTER FOLLOWS TRACK NAME
 PNTR3=I
 TRACK$=Mid$(INFO$,PNTR2+4,PNTR3-PNTR2-4)
 Print "TRACK ";TRACK$
If DLIM$="IGN" Then                      '4TH POINTER FOLLOWS ALBUM NAME
 PNTR4=I
 ALBUM$=Mid$(INFO$,PNTR3+5,PNTR4-PNTR3-5)
 Print "ALBUM ";ALBUM$
If DLIM$="ITO" Then                      '5TH POINTER FOLLOWS GENRES TYPE
 PNTR5=I
 GENRES$=Mid$(INFO$,PNTR4+4,PNTR5-PNTR4-4)
 Print "GENRES ";GENRES$
Next I
Play WAV FILENAME$
OA47
Amnesie
Posted: 08:01pm 12 Apr 2022
  OA47 said  Amnesie, if you are interesred here is what I cam up with:
This is really amazing! I definitly have use for this, thank you!
