Local Time 06:21 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite VGA 1.3 power
Rickard5
Posted: 05:01am 09 Apr 2022
I'm building the Picomite VGA 1.3 board and in my Newark Order I was backordered the TC1264 low dropout regulator Farnell 1852189. my question is can I power the Picomite VGA from USB Though the Pico? what kind of P/s supply is it really wanting ?
al18
Posted: 05:33am 09 Apr 2022
The PicoMiteVGA should work OK when powered from the MicroUSB connector on the Pico.
Posted: 07:27am 09 Apr 2022
You almost certainly can if the 3V3EN pin hasn't been pulled low on the board. I can't remember how Peter arranged it now.
Amnesie
Posted: 11:13am 09 Apr 2022
You can power the pico (vga) through USB, no problem.I tested this because the TC1264 in Germany is out of stock, too. I built me an adaptor board for the AMS1117 3.3 V LDO and it perfectly works. This part is more widely available. Even for the level shift transistors there are no parts in europe, so I used the 2N7000 instead (PINOUT!!!!).
Greetings
Daniel
Edited 2022-04-09 21:16 by Amnesie
al18
Posted: 02:04pm 09 Apr 2022
FYI the TC1264-3.3VAB is in stock at Mouser for $1.33
I would NOT recommend the LM1117T-3.3 regulator as an alternate because the pinout is different.
Posted: 02:38pm 09 Apr 2022
  Amnesie said  Even for the level shift transistors there are no parts in europe, so I used the 2N7000 instead (PINOUT!!!!).
Greetings
Daniel
I ordered BST72A's (as Peter designed it for) from Farnell. Maybe I had the last stock ?
Posted: 04:52pm 09 Apr 2022
The problem with Mouser here:
TC1264-3.3VAB  1off   1.02 UKP  (on 8 weeks delivery though)
Delivery (cheapest)  12.00 UKP
Fine if you happen to want over 30 UKP's worth of stuff, otherwise don't bother.
Posted: 05:09pm 09 Apr 2022
Any TO220 LDO 3.3V regulator will do as long as it has the standard 7805 style pinout.
Edited 2022-04-10 03:53 by matherp
Rickard5
Posted: 07:22pm 09 Apr 2022
  Quote  The problem with Mouser here:
The Problem with Mouser here is:
if I order it for $1.33 it will take 10-12 days to get here on a Slow boat across the west Texas Desert Via USPS and that will drive me mad, so I'm going to drive the 70 miles each way to the $1.33 part with Gas @ near $4.50 / Gallon in a Truck that gets 20 MPG _$12 each way in tolls and a waste of 2 hours of my Valued time
The Real problem is I'm just dumb enough to be there Monday morning @ 8:00 am to get $1.33 part
Posted: 07:29pm 09 Apr 2022
Wow...  you're taking this *really* seriously. lol
I'd order something similar (i.e. as described by Peter above) from ebay/Amazon and in the meantime power the PicoMite via its USB socket. (Don't fit the 3V3EN link on a 1.3 board). The onboard SMPS will easily supply enough 3V3 unless you plug in a load of expansion stuff.
al18
Posted: 09:38pm 09 Apr 2022
RickardS,
I just mentioned Mouser because I thought you were going to pickup the Adafruit MicroSD 3.3 volt breakout board from Mouser also.
You board will probably work fine without it.
Rickard5
Posted: 12:16am 10 Apr 2022
  al18 said  RickardS,
wow Mouser has the SD Board, Now it becomes worth the drive :)
al18
Posted: 03:13am 10 Apr 2022
Might as well get the parts for Mick’s PicoMite VGA game PCB a few posts down…
