Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10075
Posted: 06:51am 04 Apr 2022
DS3231 RTC chip NOT fitted, just using the on-board RTC.
Got this email from a client today about oddness with the RTC:
I've never seen or heard of that kind of odd RTC behaviour. Anyone else see that or can anyone comment on why he would be seeing such strange results?Smoke makes things work. When the smoke gets out, it stops!
TassyJim Guru Joined: 07/08/2011 Location: AustraliaPosts: 6632
Posted: 06:58am 04 Apr 2022
I am surprised that he/she didn't see the initial startup where you have to set the keyboard and date etc. I suggest reset all options and start over again, including removing the battery if needed.
Posted: 07:22am 04 Apr 2022
Yes, I am wondering about that myself.
I have suggested that he:
1) Power off the unit 2) REMOVE the 1220 battery 3) Power up the unit 4) Select the keyboard layout, and set the date and time 5) Replace the 1220 battery 6) Cycle power and see if the RTC settings stay correct then.
I am wondering if putting in the 1220 battery BEFORE power-up and setting of the RTC, is somehow corrupting the ARM's internal RTC module or something.Smoke makes things work. When the smoke gets out, it stops!
Posted: 11:30pm 04 Apr 2022
Further to this, got this reply:
This is very odd. I have never seen this before in the hundreds of unit I have sold.
I told him to take the battery out again, and OPTION RESET, cycle power, re-enter the keyboard layout, date/time, put battery back in again and see if that helps.
I have no idea where the 2025 and 2165 year references are coming from....that is very strange indeed. Smoke makes things work. When the smoke gets out, it stops!
Posted: 11:43pm 04 Apr 2022
OPTION RESET is not the same as pressing the reset button. He mentions pressing the reset.
You also need a few minutes of no battery and power off to discharge backup power supplies.
Peter can advice on the correct method of clearing the system fully.
