Forum Index : Microcontroller and PC projects : Gauge Colors..
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Good evening Gents.. I was putting together an HMI using the Circle type gauge that has 3 colors on it's scale... Using a simple tick timer, I was moving the gauge value up and down thru the different color sections, but the text value and gauge name wasn't matching up with scale color changes... Currently running a 64 pinner on a 5" using Ver 5.05.03... Just wondering if anyone else is seeing the same thing.. Thanks for any feedback..!! |
You need to upgrade the firmware. V5.05.04 fixed the following: "Fixed a bug which caused the legend in the GUI Circular Gauge to display incorrect colours." Geoff Geoff Graham - http://geoffg.net |
Much thanks Geoffg I didn't see the update notes..!! As always.. I totally love the family of MicroMite firmware you have shared with us all..!! I wouldn't be doing any micro controller projects without it...! Thanks..!! |
