Local Time 07:35 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Autorun
cosmic frog
Posted: 06:21pm 02 Apr 2022
Hi all.
I'm probably missing something really simple here, but,
How do I get my program to autorun on the PicoMite?
The manual says I need to make a subroutine with the name MM.STARTUP.
"When the MicroMite is first powered up it will search for this subroutine and, if found, it will be run once"
Where do I put this subroutine? Is it stored on a file on the SD card or in flash?
I just want my program to run from power up. How do I do this?
Thanks.
Dave.
Bleep
Posted: 06:42pm 02 Apr 2022
Simply set the option
OPTION AUTORUN ON
Along with any of your other options.
The program you are currently working on will then start as soon as power is applied.
cosmic frog
Posted: 06:54pm 02 Apr 2022
Ha! That simple.
So it's just like all the other 'Mites then.
I don't know how I missed that.
Anyway, Thankyou for your help.
Dave.
Posted: 09:53pm 02 Apr 2022
Just to be different, you could do this:-
Sub  MM.STARTUP
 Your Program Here.
Another Program Here.
When the first ends the second starts.
vegipete
Posted: 02:24am 03 Apr 2022
I was pondering something along these lines:
Is it possible for a particular SD card to be 'Autorun'?
Ie, stick the card in, turn on the 'mite, and the configured program runs automatically. Replace the card with a 'normal' one and the 'mite just boots to the usual command prompt.
Posted: 08:02am 03 Apr 2022
I have not tried this but give it a shot anyway, just to see what happens.
Sub  MM.STARTUP
    Load "Your-Program.BAS"
    Run
Or
Sub  MM.STARTUP
    Run "Your-Program.BAS"
Edited 2022-04-03 18:09 by phil99
Tinine
Posted: 11:26am 03 Apr 2022
PMJI but this thread just reminded me:
I had read, some time ago that OPTIONs should be command line only but I have seen AUTORUN in the source. Is this kosher?
I messed-up one time where I had modified code, using MMEdit and apparently it wiped-out the AUTORUN. When they cycled the power, the program didn't start and so I had to re-visit (200 mile round-trip).
Craig
