Forum Index : Microcontroller and PC projects : Picomite I2C BME280
| grroel.tech Newbie Joined: 09/12/2021 Location: SpainPosts: 28 |
Hello, I have connected an I2C DHT22 temperature and humidity sensor to the RPi Pico according to the instructions in the Picomite manual. It works perfectly. But I would also like to monitor the atmospheric pressure, as I have done with other controllers with a BME280 sensor. Could you show me the necessary code using the I2C interface? Thank you very much. |
Google would have found http://www.thebackshed.com/forum/ViewTopic.php?TID=8362 amongst others |
