jovian Regular Member Joined: 16/04/2017 Location: AustraliaPosts: 63
Posted: 09:17am 20 Mar 2022
HI
I want to to quickly poll 18 IR LEDs from one picomite, (via Darlington transistor arrays)
I have successfully tested a scratch piece of software that polls around the pins, and it runs no problem, with a 20 ms gap between each IR send command.
However, because the infrared commands take around 150 ms each to send, my concern is whether the firmware is smart enough to handle multiple channels of infrared sounds simultaneously, or whether the initiation of a new IR send command simply terminates any previous one.
Can anyone answer this question?
Thanks Joe Edited 2022-03-20 19:19 by jovian
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12083
Posted: 09:23am 20 Mar 2022
The IR SEND command is blocking so only one can happen at a time
