Local Time 10:42 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite and 16 Channel Servo Boards
Marcwolf
Posted: 02:10am 07 Mar 2022
Hi Folks.
Been a long while since I have been back here.
I am wondering if anyone has some code that will drive the 16 Channel Servo Controllers based on the PCA9685.
Adafruit 16 Channel Servo Controller
This is a very popular board since it runs on I2C and you can daisy chain multiple boards together.
I have been working on a 2 part project.
1. A ESP32 using the PCA9685 to control Servo's. Positions are read every 0.25 sec from a SD card and then sent to the servo. This give a resolution where a slow sweeping move can be obtained that runs over many seconds.. Not just a fast Point A to Point B movement.
2. A programmer using a PicoMite, Touch Screen, and an SD Card. This can be plugged in to a PCA9685 and the user can then use the touch screen to set the positions of the servos and record them on to the SD Card. Naming of Servo's, Min/Max, Defaults, and where the servo is reverse or not can all be included in to the code.
Afterward the CD Card can be plugged in to the ESP32 (1) and set to run.
My big issue has been trying to find a easily programmable graphics system with multiple screens. Plus I am very comfortable with using BASIC.
Can anyone help with the Servo Controller?
Many thanks
David Boccabella a.k.a. Marcwolf
Posted: 02:36am 07 Mar 2022
Should be easy enough, you just need to read the manual for the controller chip used, and translate that into MMBASIC instead of Arduino C code.
I'll have a look at the PDF for this chip and post back later, but as the chip is clever enough to keep the PWM rates running for all 16-channels by itself, it should simply be a case of using the chip PDF to work out the commands you need to send, and using the I2C commands - see the appendix's in the various user manuals, as there is an I2C section in each one.
Tinine
Posted: 03:54am 07 Mar 2022
Any reason for not simply using a slaved Picomite? Doesn't it have 16 PWMs?
Craig
disco4now
Posted: 04:17am 07 Mar 2022
Here something I used some time ago. Should be a start.
  Quote    '------------------------------------------------------------------------------'
 '       Micromite library for PCA9685                                          '
 '       Uses PCA9685 16-channel PWM over I2C to support 16 Servos  or PWM pins '
 '       Author:   Disco4now TBS Forum                                             '
 dim ProgTitle$ = "PCA9685 Test Suite"                                                '
 Dim ProgVer$   = "v1.0.0"                                                      '
 Dim ProgDate$  = "03-Apr-2018"                                                 '
 'Code for a Micromite to communicate with a PCA9685 16-channel PWM over I2C.
 'Also contains routine to allow calibration of servos.
 'The console input is scanned and characters read as they are typed
' ServoMIN(16),ServoMAX(16) hold min and max pulse widths for 0 and 180 deg respectively.
 ' nominal values 800 and 2200 but adjust to suit your particular servos
 ' calibration values for each servo
 ' 0-9,a-f used to select the servo to calibrate.
 ' SPACEBAR sets servo near the centre i.e 90 deg for nominal range of 0-180
 ' right arrow sets servo to 180 deg.SPACEBAR to reurn to centre.
 ' PgUp/PgDn increase/decrease pulse width by 10uS. Up/Down Arrows increase/decrease by 1uS
 ' Press SPACEBAR and current value will print to console.
 ' When the servo is operating correctly then record the max/min values and used them
 ' to set ServoMIN(x) and ServoMAX(x) values in the PWMInit() routine.
 ' nominal values 800 and 2200 but adjust to suit your servos
 '  e.g.
 '  ServoMIN(0)=480:ServoMAX(0)=2140
 '  ServoMIN(1)=480:ServoMAX(1)=2085
 '  ServoMIN(2)=460:ServoMAX(2)=2125
' Once these are set you just use
 ' SERVOSet(id,angle)
 ' to set individual servo to desired angle
Option Explicit
Option Default NONE
 ' Data Variables
Dim integer loc0last,loc0now,loc1last,loc1now,loc2last,loc2now,GetCon=0,GetCom1=0,GetCom2=0
Dim integer i,id=0,highlow=0
 ' Program Initialization
Print "Starting " + ProgTitle$ + ": " + ProgVer$ + " - " + ProgDate$
settick 100,IsSerialOrConsoleComplete,1
'Initialise the PCA9685 16-channel PWM over I2C at frequency of 1000
 PWMInit 50  '50Hz for 20ms pulse period represented by 4096 ticks
'Uncomment to sweep servos at start up.
'  for i=0 to 15
'    SERVOset i,0
'    pause 500
'    SERVOset i,180
'    pause 500
'    SERVOset i,90
'    pause 500
'  next i
 ' Main program loop
do
'Watchdog 40000                                  'reset after 40 secs on hang
 '==============================Check Console and Serial Ports====================================
   IF GetCon=1 then
     ReadConsole
'If data in console1 then GOSUB GetConsole
   END IF
IF GetCom1=1 then
     ReadSerial1
'If data in COM1 then GOSUB GetSerial1
   END IF
IF GetCom2=1 then
      ReadSerial2
'If data in COM2 then GOSUB GetSerial2
   END IF
 ' Procedures providing program functionality components
 'Checks console and serial ports for data and sets flag if data has stopped coming in.
 'flag triggers read of the data in the main program loop
 sub IsSerialOrConsoleComplete
'Check console and set flag if data exists and has stopped coming in
   loc0now=LOC(#0)
IF Loc0now>0 then
IF loc0now=loc0last  THEN 'data finished
     GetCon=1                'If data in CON then set GetConsole flag
    else
     loc0last=loc0now
ENDIF
END IF
'Check COM1 and set flag if data exists and has stopped coming in
'    loc1now=LOC(#1)
'    IF loc1now > 0 THEN
'     if loc1now=loc1last then 'data finished
'       GetCom1=1
'     ELSE
'      loc1last=loc1now
'     ENDIF
'    ENDIF
    'Check COM2 and set flag if data exists and has stopped coming in
'    loc2now=LOC(#2)
'    IF loc2now > 0 THEN
'     if loc2now=loc2last then 'nothin new
'       GetCom2=1
'     ELSE
'      loc2last=loc2now
'     ENDIF
'    ENDIF
end sub
'Reads data from the console
 SUB ReadConsole
local char$
LOCAL INTEGER i,j,k
      j=
LOC(#0)
      char$=
INPUT$(100,#0)
if char$<>"" then
If len(char$)=1 then
' ? char$;
          ' ? ASC(left$(char$,1));
IF Char$="0" then id=0
IF Char$="1" then id=1
IF Char$="2" then id=2
IF Char$="3" then id=3
IF Char$="4" then id=4
IF Char$="5" then id=5
IF Char$="6" then id=6
IF Char$="7" then id=7
IF Char$="8" then id=8
IF Char$="9" then id=9
IF Char$="a" then id=10
IF Char$="b" then id=11
IF Char$="c" then id=12
IF Char$="d" then id=13
IF Char$="e" then id=14
IF Char$="f" then id=15
if char$=chr$(145) then  'F1 VT100
               ? "F1"
end if
if char$=chr$(146) then  'Home VT100
               ? "F2"
end if
if char$=chr$(147) then  'Home VT100
               ? "F3"
end if
if char$=chr$(148) then  'Home VT100
               ? "F4"
end if
if char$=chr$(149) then  'F1 VT100
               ? "F5"
end if
if char$=chr$(150) then  'Home VT100
               ? "F6"
end if
if char$=chr$(151) then  'Home VT100
               ? "F7"
end if
if char$=chr$(152) then  'Home VT100
               ? "F8"
end if
if char$=chr$(153) then  'Home VT100
               ? "F9"
end if
if char$=chr$(155) then  'Home VT100
               ? "F11"
end if
if char$=chr$(156) then  'Home VT100
               ? "F12"
end if
if char$=chr$(127) then  'up arrow VT100
               ? "Del"
END IF
if char$=chr$(128) then  'up arrow VT100
             '? "Up Arrow"
             if highlow=0 then
                ServoMIN(id)=ServoMIN(id)+
1
else
               ServoMAX(id)=ServoMAX(id)+
1
end if
END IF
if char$=chr$(129) then  'down arrow
             '? "Down Arrow"
             if highlow=0 then
                ServoMIN(id)=ServoMIN(id)-
1
else
               ServoMAX(id)=ServoMAX(id)-
1
end if
END IF
if char$=chr$(131) or char$=chr$(4) then 'right arrow VT100 MMEdit
             '?"Right Arrow"
              SERVOSet(id ,180)
              highlow=
1
END IF
if char$=chr$(130) or char$=chr$(19) then  'left arrow VT100 VT100 MMEdit
              '? "Left Arrow"
              SERVOSet(id ,0)
              highlow=
0
end if
if char$=chr$(132) then
"INS"
end if
if char$=chr$(133) then
"133"
end if
if char$=chr$(134) then
"Home"
end if
if char$=chr$(135) then
"End"
end if
if char$=chr$(136) then  'PgUp VT100
             If highlow=0 then
10
else
10
end if
end if
if char$=chr$(137) then  'PgUp VT100
               if highlow=0 then
10
else
10
end if
end if
if char$=chr$(138) then
"138"
end if
if char$=chr$(139) then
"ALT"
end if
if char$=chr$(140) then
"140"
end if
IF char$=" " THEN
' ? "SPACE BAR"
               SERVOSet(id ,90)
               ? id,ServoMIN(id),ServoMAX(id);
If highlow=1 then
"  High(180)"
else
"  Low(0)"
ENDIF
endif
else
           ? char$;
endif
IF ASC(Left$(char$,1))=27  then
"ESC"
end if
end if
End if
End sub
 ' PCA9685 I2C PWM Routines
 'Original Author:- Limor Fried/Ladyada for Adafruit Industries
 'Ported to MMBasic by Disco4now!, TBS forums
 '  This is a library for our Adafruit 16-channel PWM & Servo driver
 '  Pick one up today in the adafruit shop!
 '  ------> http://www.adafruit.com/products/815
 '  These displays use I2C to communicate, 2 pins are required to
 '  interface. For Arduino UNOs, thats SCL -> Analog 5, SDA -> Analog 4
 '  Adafruit invests time and resources providing this open source code,
 '  please support Adafruit and open-source hardware by purchasing
 '  products from Adafruit!
 '  Written by Limor Fried/Ladyada for Adafruit Industries.
 '  BSD license, all text above must be included in any redistribution
SUB SERVOSet(id as integer,angle as integer)
'set individual servo to desired angle
    local integer tickoff
    tickoff=
4096*(ServoMin(id)+(ServoMAX(id)-ServoMIN(id))*angle/180)/20000
'? tickoff
    PWMSet(id ,1,tickoff)
end sub
SUB PWMSetPin(id as integer,value as integer,inv as integer)
'Helper to set pin PWM output. Sets pin without having to deal with on/off tick placement
  'and properly handles a zero value as completely off and 4095 as completely on.
  'Optional invert parameter supports inverting the pulse for sinking to ground.
  'id is PWM output pin, from 0 to 15
  'value is the number of ticks out of 4096 to be active, should be a value from 0 to 4095 inclusive.
  'inv if true, inverts the output, defaults to 'false'
'clamp value between 0 and 4095 inclusive.
    if value > 4095 then value=4095
if value < 0 then value=0
if inv=0 then
if value=0 then
'special value for fully off
        PWMSet(id ,4096,0)
else if value=4095 then
'special value for fully on
       PWMSet(id ,0,4096)
else
       PWMSet(id,
0, 4095-value);
endif
else
if value=4095 then
        PWMSet(id ,
4096,0)
else if value=0 then
       PWMSet(id ,
0,4096)
else
       PWMSet(id,
0, value);
endif
endif
end sub
SUB PWMSet(id as integer,ontick as integer,offtick as integer)
'main routine -sets the PWM output of one of the PCA9685 pins
   ' id      - One of the PWM output pins, from 0 to 15
   ' ontick  - At what point in the 4096-part cycle to turn the PWM output ON
   ' offtick - At what point in the 4096-part cycle to turn the PWM output OFF
   i2c write PCA9685_ADDRESS,0,5,LED0_ON_L+4*id,ontick and &HFF,ontick >> 8 ,offtick AND &HFF ,offtick >> 8
IF MM.I2C then ERROR "slave did not respond in PWMset"
END SUB
SUB PWMInit(freq as FLOAT)
'Select one of the following possible PCA9685 I2C Addresses in  range 40-7F
   '40 is default for no links on A5-A0 address pins.
   'Call once at the start of the program with desired frequency to be used on all pins
dim integer PCA9685_ADDRESS = &H40   'default &H40  (&H40-&H7F)
   DIM INTEGER PCA9685_MODE1=&H0
DIM INTEGER PCA9685_PRESCALE=&HFE
DIM INTEGER LED0_ON_L=&H6
DIM INTEGER LED0_ON_H=&H7
DIM INTEGER LED0_OFF_L=&H8
DIM INTEGER LED0_OFF_H=&H9
DIM INTEGER ServoMIN(16),ServoMAX(16)
'calibration values for each servo
   ServoMIN(
   ServoMIN(
   ServoMIN(
3)=475:ServoMAX(3)=2050
   ServoMIN(
4)=480:ServoMAX(4)=2160
   ServoMIN(
5)=480:ServoMAX(5)=2160
   ServoMIN(
6)=480:ServoMAX(6)=2160
   ServoMIN(
7)=480:ServoMAX(7)=2160
   ServoMIN(
8)=480:ServoMAX(8)=2160
   ServoMIN(
9)=480:ServoMAX(9)=2160
   ServoMIN(
10)=480:ServoMAX(10)=2160
   ServoMIN(
11)=480:ServoMAX(11)=2160
   ServoMIN(
12)=480:ServoMAX(12)=2160
   ServoMIN(
13)=480:ServoMAX(13)=2160
   ServoMIN(
14)=480:ServoMAX(14)=2160
   ServoMIN(
15)=480:ServoMAX(15)=2160
i2c open 10, 100
'reset the PCA9685 to power on state
   i2c write 0,0,1, &H06
IF MM.I2C then ERROR "slave did not respond at power eset"
PAUSE 1
'reset the PCA9685
   i2c write PCA9685_ADDRESS,0,2,PCA9685_MODE1, &H80
IF MM.I2C then ERROR "slave did not respond at reset"
PAUSE 1
'set pwm frequency
   if freq=0 then freq=1000   ' set a default if not set.
   PWMSetFreq(freq)
END SUB
SUB PWMSetFreq(freq as FLOAT)
'sets or changes PWM frequency.
   'freq range 40-1000 hz
   local integer mode1,GetData(1)
dim float prescaleval = 25000000/4096
dim integer prescale,currentmode
   freq=freq *
0.9 ' Correct for overshoot in the frequency setting
   prescale=INT((prescaleval/freq)-0.5)
i2c write PCA9685_ADDRESS, 0, 1, PCA9685_MODE1
i2c read PCA9685_ADDRESS, 0, 1, mode1          ' read current mode
   IF MM.I2C then ERROR "slave did not respond 2"
i2c WRITE PCA9685_ADDRESS, 0, 2,PCA9685_MODE1, mode1 OR &H10 ' set sleep bit so change of scaler allowed
   i2c WRITE PCA9685_ADDRESS, 0, 2,PCA9685_PRESCALE,prescale    'set the prescaler
   i2c read PCA9685_ADDRESS, 0, 1, GetData()          ' read prescaler
   IF MM.I2C then ERROR "slave did not respond 3"
i2c WRITE PCA9685_ADDRESS, 0, 2, PCA9685_MODE1,mode1
pause 1
i2c WRITE PCA9685_ADDRESS, 0, 2, PCA9685_MODE1,mode1 OR &HA0 'This sets the MODE1 register to turn on auto increment.
 END SUB
F4 H7FotSF4xGT
Marcwolf
Posted: 12:39pm 07 Mar 2022
DiscoNow:- WOW.. Many many thanks . This will certainly give me something to work the BASIC's from  - No pun intented.
Tinine :- Te reason for not using the PicoMite to drive the servos is that the PCA9685 is NOT limited to just 16 servos. It can be daisy chained and run over 500 servos.
Again many thanks for everyone's help.
Tinine
Posted: 04:11pm 07 Mar 2022
  Marcwolf said  DiscoNow:- WOW.. Many many thanks . This will certainly give me something to work the BASIC's from  - No pun intented.
but nothing to stop PicoMites being chained together.
I have 255 addresses on my RS422/485 full duplex link which could give me 255*16 servos.
Craig
Tinine
Posted: 07:31pm 07 Mar 2022
@Marcwolf
Sounds like you have something cool going on
I use PicoMites for system management and I/O expansion BUT the heavy lifting (real-time) stuff is handled by the Parallax P2 "Edge" module.
The P2 can give you at least 56 channels of PWM and even without over clocking, you are looking at 14bit resolution @10KHz.
This would give you the best synchronisation and coordination possible.
Programming in "FlexBasic" is a walk in the park.
EIGHT parallel processors and not as scary as it sounds
Craig
