Forum Index : Microcontroller and PC projects : CMM2: Stereo audio out sockets....
Hi all. I have run out of these, and Mouser - who I normally get them from, don't have any either. They are expecting another 9000 or so in May, but I need some now. Do any of you have some spare? I only need four to complete my hand-assembled CMM2's using the ARM chips I have here. Once they are all built and sold, I won't be making any more for at least a year till I can get more ARM chips, and by then, interest will probably have dropped off, so I expect these to be the last four I ever sell. Probably. Can anyone help? Smoke makes things work. When the smoke gets out, it stops! |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 252 |
I realize I'm on a different continent than you, but if you're looking for a thru hole 3.5 mm stereo socket, Mouser has over 5000 in stock of P/N 490-SJ1-3525NG-GR at $0.84 each |
If it's the same as the V1, RS and Element14 have stock Switchcraft 35RASMT4BHNTRX RS is very expensive, Element14 much better. Jim VK7JH MMedit |
@ al18: Thanks, but no - that is completely the wrong connector. ![]() @ Jim: Yes, that is the correct part. Agree that RS are excessively priced, and element14 have some stock, so I will get four or six from them - thanks. ![]() Smoke makes things work. When the smoke gets out, it stops! |
Ok - I see your board uses a surface mount connector. FYI Digikey also has stock of the Switchcraft connector mentioned above. |
Cool, thanks, and no offense intended. Welcome aboard the SS BackShedForums though. ![]() Smoke makes things work. When the smoke gets out, it stops! |
I can help you out grogs, PM me if still interested. I probably have 30 or more left Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
