Forum Index : Microcontroller and PC projects : Pico Basic Pin in use error reading temperature sensor
| k2backhoe Regular Member Joined: 04/12/2021 Location: United StatesPosts: 47 |
Has anyone else run into this? SOmetimes when I try to do a tc = TEMPR(gp22) instruction, I get this persistent error Error : Pin 29 is in use and once the error shows up, I can't find any way to clear it. powering down the pico overnight clears the error, but when it shows up (randomly as far as I can tell), I can no longer read this sensor. I have two identical sensors on pins 21 and 22. If one gets this error, the other one also does. I tried setpin gp22,off but it gives the same error. OpSys version is ?mm.ver 5.070401 Any hints are appreciated? thanks, k2 |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418 |
Does this, from the manual, make any difference? "TEMPR START pin [, precision] This command can be used to start a conversion running on a DS18B20 temperature sensor connected to 'pin'. Normally the TEMPR() function alone is sufficient to make a temperature measurement so usage of this command is optional. This command will start the measurement on the temperature sensor. The program can then attend to other duties while the measurement is running and later use the TEMPR() function to get the reading. If the TEMPR() function is used before the conversion time has completed the function will wait for the remaining conversion time before returning the value. Any number of these conversions (on different pins) can be started and be running simultaneously." Without TEMPR START perhaps the Pico is too quick, expecting data before the DS18B20 is ready. |
Are you running the DS18B20 powered or parasitic? If the latter try normal powered. Are you sure the chips are genuine? Most likely issue is that the response is only partly being received with enough to defeat the "no-response" timeout but not a complete data sequence |
Matherp: I am running powered by the 3.3V. The devices are "Gikfun DS18B20 Temperature Sensor Waterproof Digital Thermal Probe Sensor" from Amazon, sealed in a Stainless tube. Not sure how to check for authenticity. I may have noise on the 3.3V line I am working on eliminating it to see what difference it makes. Also Matherp: is there any accessible documentation on fault error messages not covered in the manual? Phil99: I seem to get a few errors with or without using the tempr start command. I will also investigate this further |
| expo Newbie Joined: 10/01/2016 Location: AustraliaPosts: 26 |
When I had this problem I had declared A PWM which was using the same pin (which doesn't name the pin, causing the confusion to me). expo Greg. |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
I tested my DS18B20 sensors and I have the same problem. No matter what configuration or what sensor (got many of them). Also I have a lot of false readings like -1002 and 503, for example (instead of 22'C). It is no noise what so ever. I am pretty sure it _must_ have something to do with counterfeit DS18B20 chips. A year ago I started a topic in this forum with the same issue (but for the CMM2). The genuine DS18B20 chip worked with the CMM2 but sadly I can't find my genuine one because I only had one, all my other are "fake", like 99% on the market. But the question for Peter: I can fully understand, that you won't support counterfeit chips and you stick to the original datasheet, but I know for sure (because I tested over 20 chips counterfeit against genuine on the Arduino with the DS18B20 library) all my fake chips work without any problem on the Arduino. Just wondering what the Arduino librarys make them work and the Pico and CMM2 does not. Whatever... I don't expect you to inplement a solution for this fake chips, but I am sure the problem of "k2backhoe" is that the chip is counterfeit. The genuine costs 3 times as much here in Germany and is NOT available via eBay. Greetings Daniel Edited 2022-02-24 07:04 by Amnesie |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9265 |
Try a level shifter and run one on 5V. DO NOT USE 5V ON A PICO INPUT. They *should* work over 3V0 to 5V5, but you never know. Mick Zilog Inside! nascom.info for Nascom & Gemini |
If someone wants to send me one of these non-working sensors I can look at it on the scope (send me a PM). All of mine work and since I bought a batch of 10 for < GBP5 it is unlikely they are genuine |
I resurrected the code I used to investigate the 'odd' DS18B20s that are around. You can read the original discussion here https://www.thebackshed.com/forum/ViewTopic.php?TID=12339&PID=152019#152019#152037 There are a lot of pages. I modified the code to run on the picomite. MMBasic has ONEWIRE commands available so you can talk to the DS18B20 and similar without having to use the TEMPR command. You need to set PinNbr to suit your system. This code talks directly to the suspect device and the returned data may help work out what's wrong. The rom code may indicate a suspect and the scratchpad tells us if the device was able to change resolution. 'DS18x20 test code by TassyJim DIM INTEGER PinNbr = 24 ' 22 PRINT "Family name: ";FamilyName$(PinNbr) PRINT "Rom Code: ";getRomCode$(PinNbr) PRINT "ScratchPad: ";getScratchpad$(PinNbr) IF powerMode(PinNbr) THEN PRINT "Power mode External" ELSE PRINT "Power mode Parasitic" ENDIF print "temp = "; tempr(PinNbr) FOR n = 9 TO 12 x = setResolution(PinNbr, n) PRINT "ScratchPad: ";getScratchpad$(PinNbr) 'pause 10000 TIMER = 0 PRINT "Temperature: ";getTemp(PinNbr);" ";TIMER;"mS,";n;" bit" NEXT n END FUNCTION getRomCode$(PinNbr AS INTEGER) ' get ROM Code - useful if you want more than 1 device on wire LOCAL INTEGER a1,a2,a3,a4,a5,a6,a7,a8 ONEWIRE WRITE PinNbr,1,1,&h33 'read ROM code ONEWIRE READ PinNbr,0,8,a1,a2,a3,a4,a5,a6,a7,a8 getRomCode$ = HEX$(a1,2)+" "+HEX$(a2,2)+" "+HEX$(a3,2)+" "+HEX$(a4,2)+" "+HEX$(a5,2)+" "+HEX$(a6,2)+" "+HEX$(a7,2)+" "+HEX$(a8,2) END FUNCTION FUNCTION getScratchpad$(PinNbr AS INTEGER) 'ONEWIRE Write PinNbr,1,9,&h55,a1,a2,a3,a4,a5,a6,a7,a8 'read from scratchpad ONEWIRE WRITE PinNbr,1,2,&hcc,&hbe ONEWIRE READ PinNbr,0,8,a,b,c,d,e,f,g,h getScratchpad$ = HEX$(a,2)+" "+HEX$(b,2)+" "+HEX$(c,2)+" "+HEX$(d,2)+" "+HEX$(e,2)+" "+HEX$(f,2)+" "+HEX$(g,2)+" "+HEX$(h,2) END FUNCTION FUNCTION powerMode(PinNbr AS INTEGER) AS INTEGER ' check whether power external (1) or parasitic (0) ONEWIRE RESET PinNbr ONEWIRE WRITE PinNbr, 1,2,&hcc, &hb4 ONEWIRE READ PinNbr,4,1,powerMode END FUNCTION FUNCTION getFamily(PinNbr AS INTEGER) AS INTEGER getFamily = VAL("&h"+LEFT$(getRomCode$(PinNbr),2)) END FUNCTION FUNCTION FamilyName$(PinNbr AS INTEGER) LOCAL INTEGER fn fn = getFamily(PinNbr) SELECT CASE fn CASE 16 FamilyName$ = "DS1820/DS18S20" CASE 34 FamilyName$ = "DS18S22" CASE 40 FamilyName$ = "DS18B20" CASE ELSE FamilyName$ = "Unknown" END SELECT END FUNCTION FUNCTION setResolution(PinNbr AS INTEGER,r AS INTEGER) r = r-9 IF r < 0 THEN r = 0 IF r > 3 THEN r = 3 r = r*32+31 ONEWIRE WRITE PinNbr, 1,5,&hcc, &h4E, &hFF,&hFF,r END FUNCTION FUNCTION getTemp(PinNbr AS INTEGER) AS FLOAT LOCAL INTEGER fn, t, T1, T2, a,b,c,d,e,f,g,h LOCAL FLOAT Value fn = getFamily(PinNbr) power = powerMode(PinNbr) ONEWIRE WRITE PinNbr,1,2,&hcc,&hbe ONEWIRE READ PinNbr,0,8,a,b,c,d,e,f,g,h ONEWIRE RESET PinNbr ' reset before command ONEWIRE WRITE PinNbr, 0, 2, &hcc, &h44 ' start conversion 'read external when b goes high, for parasitic just wait 'IF power = 0 THEN 'parasitic 'PAUSE 750 'ELSE ' external power 't = TIMER 'DO 'IF TIMER - t > 1000 THEN 'Value = 1000 'EXIT DO 'ENDIF 'ONEWIRE READ PinNbr, 6 , 1 , b ' conversion done? 'LOOP UNTIL b = 1 'ENDIF pause (50 << (e+1)/32) ' pause time varies depending on resolution IF Value = 0 THEN ' we have not timed out yet ONEWIRE WRITE PinNbr, 1, 2, &hcc, &hbe ' command read data ONEWIRE READ PinNbr, 2, 2, T1, T2 ' get the data ONEWIRE RESET PinNbr 'print T1,T2, T2 AND &b1000,(T2 AND &b111) SELECT CASE fn CASE 16 'DS18S20 or DS1820 ONEWIRE WRITE PinNbr,1,2,&hcc,&hbe ONEWIRE READ PinNbr,0,8,a,b,c,d,e,f,g,h IF T2 AND &h80 THEN 'if MSB of T2=1 then negative 'Read 12bit resolution and adjust 'truncate 0.5deg value (or use integer division \) T1 = T1 AND &hFE T1=T1 / 2 'make whole degrees 'add compensation values read from scratchpad T1=T1*16 'make lsb 1/16 degree T1 = T1 -4 +(16 - g) 'add 12 bit value 'take 2s complement T1 = (T1 XOR &hFF) + 1 Value = -T1/16 'make decimal value in degrees ELSE 'positive temp Value = T1 / 2 '9bit value 'Read 12bit resolution and adjust T1 = T1 AND &hFE 'truncate 0.5deg(or use integer division \) Value = T1/2- 0.25 + (16 - g) /16 '12 bit value ENDIF CASE 34, 40 ' DS18S22 or DS18B20 IF (T2 AND &b1000) THEN 'negative temp 'make 2s complement (1s complement+1) T2 = (T2 XOR &hFF) T1 = (T1 XOR &hFF)+1 IF T1=1 THEN T2=T2+1 'add the carry if required Value = -((T2 AND &b111) * 256 + T1) / 16 ELSE 'positive temp Value = ((T2 AND &b111) * 256 + T1) / 16 ENDIF CASE ELSE Value = 1000 END SELECT ENDIF getTemp= Value END FUNCTION I found that my DS18B20s work better without any external pullup. I always use external power rather than parasitic but it shouldn't make any difference to MMBasic. Note to Peter: My code usually polls the data line and waits for the end-of-conversion signal. ON the MX170, that works reliably but on the picomite the data line goes high immediately so I had to use the calculated delay instead. Not a problem for temperature measurement but it might get interesting with other one wire devices. I will do some more investigating when time permits but it looks like the strong pullup is on when it shouldn't be. Edited 2022-02-24 14:34 by TassyJim VK7JH MMedit |
I finally found my suspect chip. The TEMPR command works correctly. My do-it-yourself code doesn't, but it does for the known genuine ones. There seems to be a bit shift going on. Likely a timing issue. Jim VK7JH MMedit |
