Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10076
Posted: 05:49am 15 Feb 2022
As per title.
I don't see them mentioned in the PM manual, so I am just curious.
I am specifically wanting to use the additional ports functions such as the serial transmit and receive, and possibly the I2C and SPI transmit and receive C routines.
Yes? No?Smoke makes things work. When the smoke gets out, it stops!
panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1136
Posted: 06:07am 15 Feb 2022
CSUB... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it!
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3418
Posted: 06:17am 15 Feb 2022
Yes, and at the address below Peter provides an example. (They need to be compiled for the PicoMite, others won't work)
Posted: 02:41am 16 Feb 2022
Excellent, thanks.
EDIT: Is there a way to re-compile the serial, I2C and SPI Cfunctions/Csubs for the standard MM series to the PM? A nice simple application that converts from one to the other would be nice, but probably does not exist. Edited 2022-02-16 12:46 by GrogsterSmoke makes things work. When the smoke gets out, it stops!
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4391
Posted: 08:39am 16 Feb 2022
"Just" install the toolchain & use it, I expect.
Worked for me to build the picomite sources, so very likely the same.
(Though it will depend on what those CSUBs do. If they directly access hardware, e.g. I/O ports, those parts will need rewrites similar to the rewrites MMBasic needs on every port.)
