Local Time 13:46 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite and GPS
mrbennet
Posted: 03:14am 08 Feb 2022
Have loaded mmbasic to my pico with no problems and it is displaying the output from an em406 GPS.
How do I correct for local time? I did read what I needed to do a couple of days ago but for the life of me I can't recall the instructions!
Posted: 03:43am 08 Feb 2022
Manual P107
OPEN comspec$ AS GPS [,timezone_offset] [,monitor]
Will open a serial communications port for reading from a GPS receiver. See
the GPS function for details. The sentences interpreted are GPRMC,
GNRMC, GPCGA and GNCGA.
The timezone_offset parameter is used to convert UTC as received from the
GPS to the local timezone. If omitted the timezone will default to UTC. The
timezone_offset can be a any number between -12 and 14 allowing the time
to be set correctly even for the Chatham Islands in New Zealand (UTC
+12:45).
If the monitor parameter is set to 1 then all GPS input is directed to the
console. This can be stopped by closing the GPS channel.
palcal
Posted: 03:46am 08 Feb 2022
When you open the COM port you add another parameter
From the manual
  Quote  OPEN comspec$ AS GPS
+12:45).
Beat me to it..
Edited 2022-02-08 13:48 by palcal
mrbennet
Posted: 06:36am 08 Feb 2022
Thankyou phil99 and palcal, timezone_offset added and now have the correct time in Merbein!
palcal
Posted: 07:56am 08 Feb 2022
Been to Merbein a lovely town in a great part of Australia but too cold for me.
