Forum Index : Microcontroller and PC projects : ARM H7 and Directory name strangeness?
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2287 |
First off: I can't reload earlier firmware at this moment in time and I'm not even sure this is a firmware issue. ArmmiteH7 V5.07.01b0.bin Firmware Version 5.0701 > None of these directory names have underscore chars, and when the SD card is viewed in Windows, they show correctly without an Underscore char. Just for the hell of it I went through and renamed each directory with NO underscore char. SD card returned to the ARM H7. 1: Directory list retrieved by MMBasic DIR$ command and displayed with the Text command. M 02 D 04 M 02 D_05 *** underscore added M 01 M_02 D_03 *** two added 2: Same as above but with the SORT command used before the Text display. M 01 M 02 D 04 M 02 D 05 <- now ok M_02 D_03 *** still underscore 3: Same above but files inside the Directory, displays space after DF correctly. DF 07-55.dat DF 08-35.dat DF 09-54.dat DF 10-34.dat DF 12-48.dat DF 13-08.dat 4: Using the Files command at the Command prompt, space are replaced with underscore A:/LOG_2022 <DIR> M_01 <DIR> M_02 D_03 <DIR> M_02 D_04 <DIR> M_02 D_05 4 directories, 0 files 5: Same as above but files inside the Directory, displays space after DF correctly A:/LOG_2022/M_02 D_05 13:22 05-02-2022 49648 DF 07-55.dat 13:22 05-02-2022 49648 DF 08-35.dat 13:22 05-02-2022 49940 DF 09-54.dat 13:22 05-02-2022 49649 DF 10-34.dat 13:21 05-02-2022 49644 DF 12-48.dat 13:21 05-02-2022 49648 DF 13-08.dat 0 directories, 6 files The file names in step 5 match file names in step 3. Thoughts? BTW the directory names and file names are being created by MMBasic on the Arm-H7, not on a Win PC. However they all display correctly on Win PC. Edited 2022-02-06 08:18 by KeepIS NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
