Local Time 14:49 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Why Oh Why do I get a blank screen ?
hitsware2
Posted: 06:38pm 26 Jan 2022
TINY2040 ..... ssd1306 spi display
PicoMite V5.07.03.uf2
**** hookup *****
gp7..........D1
gp6..........D0
gp5..........Cs
gp3..........Rst
gp2..........DC
> option list
OPTION SYSTEM SPI GP6,GP7,GP4
OPTION LCDPANEL SSD1306SPI, LANDSCAPE,GP2,GP3,GP5
GUI test lcdpanel
Edited 2022-01-27 04:44 by hitsware2
my site
Posted: 06:53pm 26 Jan 2022
Are all those pins free on the Tiny 2040? I don't know it.
I don't think you should connect D0 and D1. I suspect they might be for I2C.
hitsware2
Posted: 07:20pm 26 Jan 2022
D0 & D1 are used for i2c ( which works )
but are also CLK & DATA for spi .....
D0 & D1 are printed on the display ...
Edited 2022-01-27 05:29 by hitsware2
my site
flasherror
Posted: 08:17pm 26 Jan 2022
Since there aren't a lot of pins, why not use the I2C version of this display?
Justplayin
Posted: 08:35pm 26 Jan 2022
  hitsware2 said  TINY2040 ..... ssd1306 spi display
**** hookup *****
gp7..........D1
gp6..........D0
gp5..........Cs
gp3..........Rst
gp2..........DC
> option list
GUI test lcdpanel
Your hookup pins and option pins do not match.  (gp2 verses GP4 ????)
hitsware2
Posted: 08:43pm 26 Jan 2022
  flasherror said  Since there aren't a lot of pins, why not use the I2C version of this display?
I have the i2c version working.
I want to compare the speed ...
my site
hitsware2
Posted: 09:13pm 26 Jan 2022
@Justplayin
GP2 is DC ( goes to DC pin on display )
GP4 is MISO ( not used with display )
OPTION SYSTEM SPI ( from manual )
CLKpin, MOSIpin, MISOpin
# Specify the SPI port and pins for use by system devices (SD card,
 LCD panel, etc).
 The PicoMite uses a specific hardware SPI port for system devices,
 leaving the other for the user. This command specifies which pins are
 to be used, and hence which of the SPI ports is to be used. The pins
 allocated to the SYSTEM SPI will not be available to other MMBasic
 commands.
 This command is not available on the PicoMiteVGA.
SPI Based Display Panels ( from manual )
These panels are configured using the following commands.
In all commands the parameters are:
# OR = This is the orientation of the display and it can be LANDSCAPE, PORTRAIT,
 RLANDSCAPE or RPORTRAIT. These can be abbreviated to L, P, RL or RP.
 The R prefix indicates the reverse or "upside down" orientation.
# DC = Display Data/Command control pin.
# RESET = Display Reset pin (when pulled low).
# CS = Display Chip Select pin.
Any free pins can be used.
Edited 2022-01-27 07:18 by hitsware2
my site
Posted: 10:02pm 26 Jan 2022
Just a thought...
I wonder if D0 and D1 are doing what you think in SPI mode?
Have you tried swapping them round? You could put 1k resistors in the leads to protect against connecting two outputs together.
Ah... you may have to move resistors on the display to change modes:
https://electronics.stackexchange.com/questions/164680/ssd1306-display-spi-connection-or-i2c-according-to-resistors
https://learn.adafruit.com/monochrome-oled-breakouts/wiring-128x64-oleds
Edited 2022-01-27 08:08 by Mixtel90
hitsware2
Posted: 01:40am 27 Jan 2022
  Mixtel90 said  Just a thought...
Yes (now) Still no go ....
my site
