Local Time 14:47 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite OPTION AUDIO
palcal
Posted: 07:28am 23 Jan 2022
I am using the OPTION as per the manual...OPTION AUDIO PWM GP18,GP19
but get and error 'Expression Syntax'
What am Idoing wrong.
Posted: 07:38am 23 Jan 2022
Which version of the PicoMite firmware are you running? You can't use those pins with the VGA version. Use PRINT MM.VER to find out if you aren't sure. Otherwise your command looks OK to me.
palcal
Posted: 07:50am 23 Jan 2022
V 5.07.03 the latest version NOT VGA version.
Edit...Just checked MM.VER gives 5.0703
Edited 2022-01-23 17:52 by palcal
Posted: 07:54am 23 Jan 2022
Seems strange then. I've not got a non-VGA version set up at the moment. I'll do one and see what happens. I assume you've not allocated tose pins to anything else. Have you tried different pins, such as GP16 / GP17 to get PWM0?
palcal
Posted: 07:57am 23 Jan 2022
No havn't tried other pins, checked that these were not in use so tried to use them.
palcal
Posted: 08:02am 23 Jan 2022
Just tried GP0 and GP1,  same error
Posted: 08:11am 23 Jan 2022
Found it, I think. The command is
OPTION AUDIO GP18,GP19
I found the bit about PWMn a little confusing, never having used the audio out.
palcal
Posted: 08:21am 23 Jan 2022
That works, Thanks Mick
Manual is misleading I've let Geoff know
  Quote  Example, OPTION AUDIO PWM GP18,GP19 would use PWM1A
and PWM1B on pins 24 and 25 respectively.
Should be
  Quote  Example, OPTION AUDIO GP18,GP19 would use PWM1A
Posted: 09:53am 23 Jan 2022
deleted, ignore
Edited 2022-01-23 19:54 by CaptainBoing
flasherror
Posted: 12:01pm 23 Jan 2022
Peter/Geoff,
1. Also see https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=14485&LastEntry=Y#180920#180916 for OPTION AUDIO question regarding left/right audio channel, as manual may need updating.
2. Is it possible to use just one PWM as Picomite audio output channel, leaving the other one free for I/O use? Ran out of I/O but need audio for playing sounds and mono audio is acceptable. There doesn't seem to be a way to config as mono, only stereo.
Edited 2022-01-23 22:05 by flasherror
palcal
Posted: 08:51pm 24 Jan 2022
Still playing around trying to get some audio for an alarm sound. Still waiting on a small amp. Meantime I tried to use PWM to create a tone.
Picomite V5.0703
I have used....SetPin GP18,PWM1a  and then...PWM 1,1000,50 to generate the tone but
I get an error...Pin not set for PWM.
Posted: 09:20pm 24 Jan 2022
PicoMite 5.0703
This works for me:
SETPIN GP18, PWM1A
PWM 1, 1000, 50
palcal
Posted: 11:08pm 24 Jan 2022
I had option audio set on that pin, I since deleted the option but wonder if that is the problem. I'll try another pin.
Edit.    I tried...SetPin GP4,PWM2a  and  PWM 2,1000,50
and get the same error Pin not set for PWM.
Might be time to reflash the Pico.
Edited 2022-01-25 09:22 by palcal
palcal
Posted: 11:38pm 24 Jan 2022
OK I reflashed the chip but same problem.
Peter's post said...
  Quote  The 5.07.03 firmware is now released and available on Geoff's site together with the updated manual covering both versions
Warning: Loading these binaries will automatically wipe all flash the first time loaded so back up anything important first (clear_flash not necessary). This takes a few seconds before you will get the USB connection.
...but when I reflashed, the old code was in memory and the flash slots were unaltered.
palcal
Time to try another Pi Pico.
palcal
Posted: 02:43am 25 Jan 2022
Well the new PiPico does the same thing, below I have listed my code.
A digital speedo for my car with overspeed alarm. When the speed limit is exceeded the display turns RED and an alarm sounds (I wish).
When in use touching the screen left top sets 60kph in the middle sets 80kph and bottom left corner sets 100kph.
I simulated it's use by adding x=55 and in the loop SPD=x and incrementin x by 1 each pass with a 1 sec. pause.
When first started you have to be quick to touch the screen to set the limit.
If no GPS connected just comment out the respective lines.
' GPS SPEEDOMETER (PICOMITE)
' Paul Cahill----Jan 2022
'OPTION SDCARD GP22
'OPTION SYSTEM SPI GP10,GP11,GP12
'OPTION LCDPANEL ST7789_320, LANDSCAPE,GP8,GP15,GP9,GP13
'OPTION TOUCH GP16,GP17
'GUI CALIBRATE 0, 408, 3901, 900, -646
CLS RGB(175,255,240)
COL = RGB(Yellow)
SetPin 1,2, COM1
SETPIN 15, INTL, AlSet
SetPin GP18,PWM1a
Open "COM1:9600" As gps,10                     ' open the GPS serial interface
 Text 155,100, "Searching For", CM, 1, 2, RGB(black)
 Text 160,130, "Satellites", CM, 1, 2, RGB(black))
Loop While GPS(Valid) = 0
CLS (Black)
 PWM 1, OFF
 COL = RGB(Yellow)
 am$="am"
 Date$ = GPS(Date)
 SPD = Cint(GPS(Speed)*1.852)
 SPEED$ = Str$(SPD,4)
 IF SPD > (SpSet + 2) and SPD < (SpSet + 6) Then
 COL = RGB(Red)
 Alarm
 Endif
 Time$ = GPS(Time)
 Hour$ = Left$(Time$,2)
 Minute$ = Mid$(Time$,4,2)
 If Val(Hour$) >12 Then
   Hour$ = Str$(Val(Hour$) - 12)             '12 Hour Mode
   am$ = "pm"
   HR = Val(HOUR$)
     Hour$ = Str$(HR)                         'Remove the leading zero
   Ti_me$ = Hour$+":"+Minute$
 ALTITUDE$ = Str$(Cint(GPS(Altitude)))
 ' display the date and time for this second
 Text 50,12,"SET "+Sp_Set$,CM,1,2,RGB(Yellow),RGB(Black)
 Text 235,12,Ti_me$+" "+am$,CM,1,2,RGB(Yellow),RGB(Black)
 Text 90,120,SPEED$,CM,8,1,COL,RGB(Black)
 Text 260,160,"kph",CM,1,2,COL,RGB(Black)
 Text 70,220,"Alt "+Altitude$+"m.",CM,1,2,RGB(Yellow),RGB(Black)
sub AlSet
If Touch(Y) < 100 Then SpSet = 60
If Touch(Y) >100 and Touch(Y) < 200 Then SpSet = 80
If Touch(Y) > 200 Then SpSet = 100
Sp_Set$ = Str$(SpSet)
SUB Alarm
PWM 1,1000,50
End sub
Edited 2022-01-25 12:45 by palcal
Posted: 02:52am 25 Jan 2022
When you turn the PWM OFF, you free up the pin.
This gives the error when you try and create a tone.
rem out the PWM 1,off and try.
palcal
Posted: 02:55am 25 Jan 2022
Thanks Jim, how do I stop the alarm sounding. In the Micromite there was the command PWM STOP maybe its the sane for the Pico but it's not in the manual.
Edit.  OK The PWM command now OK, PWM STOP didn't work. I'll just move the SetPin command to the beginning of the loop I Think that will do it, but have to wait till I get my amp. or a piezo so I can hear it.
Edited 2022-01-25 13:31 by palcal
Posted: 07:14am 25 Jan 2022
ON the CMM2, STOP does the same as OFF on the Pico
  Quote  The PWM function will take control of any specified outputs and when
stopped the pins will be returned to a high impedance "not configured" state.
