Local Time 15:41 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C troubles
georgestheking
Posted: 10:31am 21 Jan 2022
I make this to read a GY-26 compass :
REM-------------------------
REM PICOMITE 5.0703
REM -----------------------
option default integer
option explicit
DIM INTEGER RDATA(8)
SETPIN GP2,GP3, I2C2
sub compass
I2C2 OPEN 100, 1000
I2C2 WRITE &HE0, 0, 1, &H31 ' send read command &h31
I2C2 READ &HE1, 0, 8, RData() ' read 8 datas registers
I2C2 CLOSE
end sub
DO
compass
print rdata(0)
print rdata(1)
PAUSE 1000
LOOP
END
but i get an error : "pin not set for I2C2"
I use version 5.0703
Best regards
Georges
Posted: 10:36am 21 Jan 2022
IIRC
I2C2 CLOSE
releases the pins, so the second time you enter compass() they are not set. To resolve move the SETPIN into compass() or the OPEN/CLOSE out of compass().
Posted: 10:51am 21 Jan 2022
It looks like you have included the read/write bits in the address: E0 and E1
Just use the 7bit address and MMBasic adds the required direction bit
georgestheking
Posted: 10:53am 21 Jan 2022
Tom,
Thanks, no more error.
But I get 0,0.
Has anybody experience with the GY-26 compass ?
Best regards
Georges
georgestheking
Posted: 02:11pm 21 Jan 2022
Thanks Jim,
The code is now :
Rem -------------------------
Rem PICOMITE 5.0701
Option default integer
Option explicit
Dim INTEGER RDATA(8)
Rem  COMPASS GY-26
Sub compass
SetPin GP2,GP3,I2C2
I2C2 OPEN 100,1000
I2C2 WRITE &HE0,0,2,0,&H31 ' send read command &h31
I2C2 READ &HE0,0,8,RData() ' read 8 registers
I2C2 CLOSE
DO
compass
print rdata(1)
print rdata(2)
PAUSE 1000
LOOP
But still return 0,0 !!!
Best regards
Georges
PS : pull up resistors are in the right place
Posted: 02:26pm 21 Jan 2022
You do know that the first element of rdata is rdata(0) don't you, unless you specify OPTION BASE 1 ?
Posted: 02:29pm 21 Jan 2022
Hi george,
You should use the 7 bit I2C address.
The &hE0 is an 8 bit address, use &h70 in stead.
Seen TassyJim's post?
georgestheking
Posted: 02:32pm 21 Jan 2022
Woaww
It work now !
Many thanks Volhout,
I spent a complete day with this problem.
Best regards
Georges
georgestheking
Posted: 02:44pm 21 Jan 2022
Thanks to the complete team for the help,
The right code:
Rem PICOMITE 5.0703
Option explicit
Dim As INTEGER RDATA(8)
Dim As integer P,R
Rem  COMPASS GY-26
Sub compass
SetPin GP2,GP3,I2C2
I2C2 OPEN 100,1000
I2C2 WRITE &H70,0,2,0,&H31 ' send read &h31
I2C2 READ &H70,0,8,RData() ' read 8 registers
I2C2 CLOSE
compass
R=rdata(1)*256+rdata(2)
Print R
Print
Pause 1000
End
Edited 2022-01-22 00:45 by georgestheking
Posted: 02:59pm 21 Jan 2022
Glad you got it working. Note that the customary way to show code in a post is to include it within the forum tags "[ CODE]" and "[ /CODE]" (without the quote marks and without the space following "[".
Like this:
Rem PICOMITE 5.0703
Option explicit
Dim As integer P,R
Rem  COMPASS GY-26
Sub compass
 SetPin GP2,GP3,I2C2
 I2C2 OPEN 100,1000
 I2C2 CLOSE
 compass
 Print R
 Print
 Pause 1000
End
Note that this preserves indentation if your code has any.
