Local Time 15:40 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USB keyboard mimic
BeagleHound
Posted: 02:35am 21 Jan 2022
Does anyone have suggestions on how a micro/maxi/pico/arm-mite may be used to interface a panel of switches to a PC, by mimicking a USB keyboard?
To me, the most difficult part seems to be the USB interface. Many on-line solutions suggest this can be done using a small micro-controller having built-in USB HID support, such as the ATmega32u4 or the SparkFun ProMicro. If I can avoid it, I would rather not have to learn from scratch, how to use another micro-controller.
Posted: 03:37am 21 Jan 2022
Hi Beagle hound,
Grab a cheapo keyboard and hack the chip out of it, use your  push buttons to emulate keys from the keyboard by patching them where the relevant keyboard key would have been.
These are generally a matrix of X-Y and should be very easy and very cheap.
BeagleHound
Posted: 04:20am 21 Jan 2022
That's genius Mick.
Thank you.
Posted: 06:06am 21 Jan 2022
If you don't want a direct connection there are IR remotes with receiver USB dongles for PCs. Usually used with media programs. They show up in Device Manager as a HID Compliant Keyboard. The companion app allows the buttons to be assigned to whatever keyboard key combination you like. You could use Bigmick's method on that.
Posted: 08:09am 21 Jan 2022
@BeagleHound following on from Mick, see this vid: https://www.youtube.com/watch?v=gIlYJSO7lok Not precisely what you are after but the principal is identical and it shows how AS evicerated the keyboard and sussed out the chip. The goodies for you starts around 6 minutes in.
Edited 2022-01-21 18:18 by CaptainBoing
Frank N. Furter
Posted: 08:42am 21 Jan 2022
Hi!
Or you get a HT82K629A and build my keyboard emulator.
I developed the part a few years ago for my MAME project.
With it you can connect any button and create any keyboard key.
You can use it on USB AND on PS/2!
Frank
ElectroPI
Posted: 10:56am 21 Jan 2022
If you install CircuitPython on a PICO it allows HID control so you can easily mimic a USB keyboard or mouse. There's more info here:
https://learn.adafruit.com/diy-pico-mechanical-keyboard-with-fritzing-circuitpython/code-the-pico-keyboard
Links on that page will direct you to more info on the subject.
regards
Peter
Posted: 11:42am 21 Jan 2022
  Frank N. Furter said  Hi!
Nice!
I might build one just to have it - never know when that might come in handy
Posted: 12:13pm 21 Jan 2022
Before you get too excited, Farnell does not stock the chip anymore...
Posted: 12:33pm 21 Jan 2022
I like the CircuitPython approach. Probably cheaper than the chip was too.
Posted: 02:10pm 21 Jan 2022
  Volhout said  Before you get too excited, Farnell does not stock the chip anymore...
dozens on ebay. 2GBP each
BeagleHound
Posted: 07:37am 22 Jan 2022
Thanks for all the interesting suggestions and links. I have much to ponder.
BeagleHound
