Local Time 16:41 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic subroutine parameters
Turbo46
Posted: 04:30am 12 Jan 2022
This may not be of interest to anyone but..
While I was reading the manual the other day, it struck me that subroutine parameters are treated in the same way as locals. They exist only within the subroutine and disappear when the subroutine returns. Also, when a subroutine is called, any parameters missing in the call are set to zero or null as appropriate.
So why not use an extra parameter as a local. It saves an extra line, probably quicker, but not only that it works!
It could be used by someone wanting to write a short and/or obtuse program or perhaps to save memory?
I Expect unused parameters in functions will behave the same way.
  Quote  ' Subroutine parameter test
X =
5 : ? "x = "; : ? x
y =
4 : ? "y = "; : ? y
Swap x, y
"now:"
"x = "; : ? x
"y = "; : ? y
Xch x, y
"return them:"
"x = "; : ? x
"y = "; : ? y
SUB Swap a, b
LOCAL t
 t = a
 a = b
 b = t
END SUB
SUB Xch a, b, t
 t = a
 a = b
 b = t
END SUB
Pluto
Posted: 07:00am 12 Jan 2022
And if the variable type is different in MAIN and SUB, the the result is different.
Dim As FLOAT x,y  '!!!!!!! FLOAT
X = 5 : Print "x = "; : Print x
y = 4 : Print "y = "; : Print y
Swap x, y
Print : Print "now:"
Xch x, y
Print : Print "return them:"
Sub Swap a As integer, b As integer    '!!!!! INTEGER
 Local t
 t = a
a = b
 b = t
Sub Xch a As integer, b As integer, t As integer
 t = a
 a = b
 b = t
RUN
x =  5
y =  4
now:
x =  5
y =  4
return them:
x =  5
y =  4
/Fred
Turbo46
Posted: 07:41am 12 Jan 2022
Well done Fred,    But I didn't say it was idiot proof. Of course if you do something stupid you make any program produce errors. I'm an expert at that.
The Swap subroutine is a copy and paste from Geoff's manual. My version is to just test a concept.
Do the same using the Swap subroutine twice.
Please explain why it is invalid to use one or the other.
Pluto
Posted: 09:44am 12 Jan 2022
I hope you do not expect me to explain...
I have a long career of producing errors. At least from some of them I did learn something.
/Fred
Posted: 09:55am 12 Jan 2022
This could be the start of our very own Obfuscated BASIC Contest (sort of like the International Obfuscated C Code Contest).
Posted: 10:11am 12 Jan 2022
  Turbo46 said  This may not be of interest to anyone but..
Hmmm... very interesting. I have a bit of an obsession with "optimising" and stuff like this scratches that itch for me.
Another thing I sometimes do in time critical Subs is to use globally defined variables as temporary storage (what might ordinarily be Locals). Of course you need to pay attention that bits of your code aren't trampling over each others work but it can give a speed boost in tight loops.
I will play. Thanks
Edited 2022-01-12 21:53 by CaptainBoing
