Local Time 17:46 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICOMITE RUNS UNDER XP AND WIN7
rentner111
Posted: 09:23pm 08 Jan 2022
I run the Picomite in a simple way without USB and
MMEdit version 3.8.1.
This also avoids the USB problem with constantly reconnecting.
The following procedure:
1. Download version 5.07.03
2. Unzip
3. Press the button on the Picomite and plug in the USB.
4. Copy the program >Clear_flash.uf2< into the Pico drive
5. Then copy the program >PicoMiteV5.07.03R8.uf2< into the Pico drive.
6. Then switch CONSOLE to PIN11 + PIN12 = COM #1.
  Enter >OPTION SERIAL CONSOLE 12,11< with Terraterm, COM #2 is.
7. Unplug the USB
8. Connect the USB link: TX via 1k to PIN12 and RX via 1k to PIN11
                         GND to PIN18   VBUS to PIN39 = VSYS (if required)
9. Start MMEDIT and select USB with >CONNECT< .
  Don't forget to set the baud rate to 115200.
  Set MMEDIT >SYNTAX< to PiCromite.
10. Work as usual with the MM170.
Edited 2022-01-09 19:38 by rentner111
