Local Time 17:47 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - Strange PIN behavior
Andrew_G
Posted: 09:31pm 31 Dec 2021
Happy New Year to you all.
I am struggling to understand some strange PIN output on my PicoMite (ver 5.0701).
I have cleared the Pico and loaded everything from scratch several times.
I'm running the following code via MMEdit v5 and have pin GP6 connected to pin GP7.
The connections are sound and not intermittent.
I can make/break the pin GP6 to GP7 connection.
I expect the print statement to show GP6 as '0' when it is broken and '1' when it is made.
It intermittently:
- fails to change from 0 to 1 and vice versa
- works properly
- starts with the wrong value even when started from a powerdown/up or re-load of the code.
Is it me or something else?
Cheers, Andrew
 'PinTest.BAS
 SETPIN GP6, DIN
 SETPIN GP7, DOUT : PIN(GP7)=1
   PRINT "GP6= ";PIN(GP6), "   GP7= "; PIN(GP7)
   PAUSE 1000
 LOOP
Posted: 09:39pm 31 Dec 2021
with the link between 6 and 7 broken, there would be a high impedance input on 6. That would be unstable.
Andrew_G
Posted: 09:50pm 31 Dec 2021
Thanks Jim.
How then can I test if a pin is high or low?
(I'm trying here to to get I2C comms to a Laser Distance sensor (for a water tank) to work. I think it relies on a pin being held high and I want to test that it is.)
Cheers,
Andrew
Posted: 10:11pm 31 Dec 2021
Hi Andrew,
Make your input pin analogue and put a 10k to Gnd and another 10k to 3.3V.
You can then see if the output pin is high, low or off.
Andrew_G
Posted: 10:14pm 31 Dec 2021
Thanks Phil.
Will do.
Andrew
