Local Time 17:47 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Start .BAS scripts without keyboard
Vampire05
Posted: 02:27pm 30 Dec 2021
Hi guys,
I want to put an armmite and a touch screen in one case. I would like to be able to see and run the BAS files on the system.
My first idea was to emulate a few keys (ESC, Curser, F-keys,...) via GPIO or PS/2 so I can navigate in the fileexplorer. But how do I start the command "files" and how do I simulate CTRL-C.
Or is there a file explorer with touch support? Then I can save the keys completely.
What is the best way to do this?
Best regards
Artem
Posted: 03:20pm 31 Dec 2021
I'm not sure what the Armmite F4 is capable of now. The PicoMite supports CHAIN to allow you to pass control to programs stored in flash, but that might be just on that platform.
Simply using FILES [fspec$] will let you display the files in the current directory of the SDcard and RUN file$ will run a file. I don't think you can run the file manager from inside MMBasic though.
Posted: 07:13pm 31 Dec 2021
Yes, you could write a program to do what you are asking.
I did it for the CMM2.
The F4 would be slightly different but doable.
You could start with my CMM2 version and remove the unnecessary bits:
https://www.c-com.com.au/mmhelp/filemanager.htm
Vampire05
Posted: 07:25pm 31 Dec 2021
Ok, thats a simple and nice solution. Thank you Mick and thank you Jim ;-)
Edited 2022-01-01 05:26 by Vampire05
