Local Time 12:37 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Python Serial On Pi Pico
Andrew_G
Posted: 01:03am 30 Dec 2021
Hello all,
I am trying to use my VL53L1X laser distance sensor on a Pi Pico.
As mentioned (here) I can get it working with Python (supplied with the sensor) but I can't see how to port the Python code to MMBasic (that would be my preference). If anyone is interested I can post the Py code, datasheet etc? (please . . . ?).
A second way I have tried is to modify the Py code to output the data to an HC12 (I am reasonably familiar with them). I have copied Lew247's code where he does the same thing.
But I get an error.
This is my code snippet:
from PiicoDev_VL53L1X import PiicoDev_VL53L1X
from time import sleep
import serial
ser = serial.Serial(
  port='/dev/ttyAMA0',
  baudrate = 9600,
  parity=serial.PARITY_NONE,
  stopbits=serial.STOPBITS_ONE,
  bytesize=serial.EIGHTBITS,
  timeout=1
distSensor = PiicoDev_VL53L1X()
while True:
   dist = distSensor.read() # read the distance in millimetres
   print(str(dist) + " mm") # convert the number to a string and print
   sleep(1)
and the error I get:
>>> %Run -c $EDITOR_CONTENT
Traceback (most recent call last):
 File "<stdin>", line 4, in <module>
ImportError: no module named 'serial'
My intention is that when I can successfully open the port and test it, I'll insert code in the while loop to write to the port.
Some questions:
- is there a subroutine or library that I need to load for serial (if so where is it and how do I load it?)
- how does one write to the port (its not as simple as PRINT #1, "Hello World" is it?)
- how does one specify which Com port on the Pico to use? (I'm happy with Com1 on GP0 and GP1 but can use another).
Many thanks,
Andrew
Justplayin
Posted: 06:06am 30 Dec 2021
Looking at the docs for the sensor, it say the device is I2C. Check the Picomite docs for the proper I2C pin connections and commands.
I believe the manufacturer of sensor expects you to only use their C API and provides no other information on how to access the sensor.
Andrew_G
Posted: 07:06am 30 Dec 2021
Thanks Curtis,
Yes it is I2C.
I bought the module from Core Electronics (in Aus.) and they supply the following Python code:
Piico Software.zip
This is what I can successfully run. It uses Pins GP08 & GP09 for SDA and SCL.
I'd dearly like to port that code to MMBASIC.
The snippet of code above is 'MAIN.PY' in the zip.
If I can get serial to work I hope to modify Main to write the data to an HC12.
(I can't see any way of getting their C API (I've looked for days). I wouldn't know how to use it either . . .).
Thanks again,
Andrew
Justplayin
Posted: 07:46am 30 Dec 2021
I have PMed some info to you.  Hope it helps.
Tinine
Posted: 08:26am 30 Dec 2021
This one looks pretty cool :)
Andrew_G
Posted: 09:59am 30 Dec 2021
Justplayin,
This is my second attempt to thank you. Thanks.
I'll report back when I can test your suggestions.
Cheers,
Andrew
Andrew_G
Posted: 03:10am 02 Jan 2022
JustPlayin,
Thanks for the suggestions but no joy yet.
But I did find a link to ST's API here.(Its in C so that will make it harder.)
It appears to be the basis of the Python code I've been looking at (it has the same comments) so I will see how I go in MMBASIC.
Andrew
Justplayin
Posted: 04:36am 02 Jan 2022
Oh well...  Sorry it didn't help.
--Curtis
Tinine
Posted: 06:30am 02 Jan 2022
@Andrew_G
Same device but packaged and with a serial ASCII mode
Andrew_G
Posted: 07:29am 02 Jan 2022
Hi Tinine,
Many thanks and a Happy New Year to you.
Well spotted!
I've ordered one but who know what and when it will turn up ...
(I reckon that the bottle of decent Aussie. red that I'm about to finish is about the same cost, Pepperjack Cab. Sav.).
I'm still keen to get the existing one working because I have uses for both.
Thanks again,
Andrew
Tinine
Posted: 09:21am 02 Jan 2022
@Andrew_G
Heck, that vino rosso idea has my mouth watering.
My one and only attempt at drinking during this holiday was a 6-hour visit to the pub but I went, armed with an Android tablet and a W10 tablet
Only got through 3 pints
Wine, cheese and crackers might be the order of the day
Posted: 09:45am 02 Jan 2022
I managed a whole 2 glasses of wine - on different days. Cheap to keep, me.
Keep taking the tablets.  ;)
Andrew_G
Posted: 11:10am 02 Jan 2022
I lived in Cheadle (Cheshire) for three years (in my late 20s). I managed a pint of Guinness at each of its eight pubs - walking only, a little awkwardly at the end!
Arrgh - a misspent youth, I didn't drink until I was 21.
Cheers,
Andrew
Andrew_G
Posted: 10:13pm 20 Jan 2022
G'day all,
This is only a quick report as I'm rushing to get out of town for a few days BUT!
My device arrived and it works a treat!
It is labelled as a "VL53L-400" and described as a "WT53D"
There are links to WitMotion's PC software or connections to the Picomite for either I2C or Serial.
It took me 10 minutes to get the serial working (at 115200 baud).
In that mode it just spits out readings continuously. They seem about right but I havnt confirmed their accuracy yet.
My next steps are to send it to an HC12 every x seconds and to test it over water.
More info in a day or three but I'll try to answer questions in the meantime.
(I had wasted a heap of time unsuccessfully trying to get Python to do serial or to get MMBasic to talk to my original VL53L1X - I'm happy with my recent purchase).
Cheers,
Andrew
Tinine
Posted: 01:37pm 21 Jan 2022
@Andrew_G
I was hoping that you would report back.
Definitely keen to learn more about this device. Would be even better if you could make vids of your experiences.
Cheers,
Craig
Tinine
Posted: 01:15am 12 Feb 2022
It's been a bit more than "a day or three"
I think I might be ordering a few of these things
Craig
Andrew_G
Posted: 06:22am 12 Feb 2022
Hi Craig,
Sorry about the delay but I do have good excuses.
No vids but it really is trivial to get them working and measuring distances and reporting via serial on HC12 on a MMBasic on a Picomite (or I guess many others too).
I have two units but will get more when I've sorted my life out.
I can't do much else at present:
- all my gear is packed into boxes for removalists
- we are due to demolish this house in a few weeks but don't yet have anywhere for us or the gear
- still changing house design for signing contracts in a week or two
Andrew
Edited 2022-02-12 16:56 by Andrew_G
Andrew_G
Posted: 06:59am 12 Feb 2022
Craig et al,
Here is my code for what it is worth:
'Pico@Wit TBS.BAS
'Uses Com1 to talk to a WitMotion V53L laser ditance sensor
'Com2 writes to an HC12, with a checksum should you wish.
'Connections:
'Pico    V53L
' 3V3 to Vcc
' GND to GND
' GP0 to RXD (Green)
' GP1 to TXD (Yellow)
'        SCL n/c
'        SDA n/c
'Pico    HC12
' 3v3 to Vcc
' GND to GND
' GP4 to RXD
' GP5 to TxD
'        SET n/c
'option Explicit  'zzz next job
'Option Autorun ON  'best done from the Console
 Dim String Dat, Range, In_Char, Out, Message
 Dim Integer OK, Rng_Ave, Ave_Count = 5, Count 'Flag set if "Range Valid" (VALID is an MMBasic keyword)
 Dim Integer Range_Start, Range_End, Chksum
 Dim Integer Range_Freq = 4000                 'Frequency of getting Range data m_seconds
 SETPIN GP0, GP1, COM1                         'Assign the I/O pins for the first serial port for V53L
 setpin GP4, GP5, COM2                         '           I/O pins for the HC12
 OPEN "COM1:115200" AS #1 'open the first serial port (V53L default speed is 115200)
 open "COM2:9600"   as #2 'open the second serial port with a speed of 9600 baud (for my HC12 network)
 Send_Message "Starting"
 SETTICK Range_Freq, Get_Range, 1  'Get a range every 'Get_Range' m_seconds - change to suit
 do'zzz Do something useful in here?
   Watchdog Range_Freq * 3 'If program is hung start again
 CLOSE #1
end
Sub Send_Message(Txt$)
 Txt$ = Txt$ + "," + time$ + "," + Date$
 Print Txt$
 Out = "$AGRNG," + Txt$  'These are my NMEA-like sentences
 Out = CRC$(Out)
 print #2, Out
End Sub 'Send_Message
Sub Get_Range
 Local Integer OK = 0, Count = 0, Rng_Ave = 0
'All other variables are Global
 Timer = 0
 do
   Dat = ""
   If Timer > Range_Freq * 0.9 then
     Send_Message "Quitting Sub"
     Exit Do  '
   End If
   do
     IF LOC(#1) > 0 THEN
       In_Char = INPUT$(1,#1)
'       Do we have a LF or CR character = end of line?
       If asc(mid$(In_Char,len(In_Char),1))=10 or asc(mid$(In_Char,len(In_Char),1))=13) then
         Exit do
       Else
         Dat = Dat + In_Char
       end if
     END IF
   loop
   If Instr(Dat, "Range Valid") then
     If Not OK then
       OK = 1  'This will hold for the duration of the Sub
     End if
   End If
   if Instr( Dat, "Signal Fail") then OK = 0: Send_Message "Signal Fail"
   if Instr( Dat, "No Update")   then OK = 0: Send_Message "No Update"
   If OK then  'This will be OK for subsequent reads until next time period. It will then start as false
     Range_Start = Instr(Dat,"d:")
     Range_End =   Instr(Dat," mm")
     If Range_Start >0 and Range_End >0 then 'We have a valid range (it has both a Start and an End)
       Range = mid$(Dat, 1, Range_End)
       Range = mid$(Range, Range_Start+2)
       Range = Trim$(Range, " ")
       If Count < Ave_Count then
         Rng_Ave = Rng_Ave + vaL(Range)
         Count = Count + 1 'ZZ use to count valid Ranges for average
         print Range, Count
       Else
         Rng_Ave = Rng_Ave / Count
         Range = str$(Rng_Ave)
         Out = "$AGRNG,"+ Range
         Out = CRC$(Out)
         print "Ave = "; Range; tab(15);Out$
         Print
         print #2, Out
         OK = 0
         Exit Do
       End if
     Else
     End If
   End if
 loop
End Sub  'Get_Range
' trim any characters in c$ from the start and end of s$
Function Trim$(s$, c$)
 Trim$ = RTrim$(LTrim$(s$, c$), c$)
End Function
' trim any characters in c$ from the end of s$
Function RTrim$(s$, c$)
 RTrim$ = s$
 Do While Instr(c$, Right$(RTrim$, 1))
   RTrim$ = Mid$(RTrim$, 1, Len(RTrim$) - 1)
End Function
' trim any characters in c$ from the start of s$
Function LTrim$(s$, c$)
 LTrim$ = s$
 Do While Instr(c$, Left$(LTrim$, 1))
   LTrim$ = Mid$(LTrim$, 2)
End Function
FUNCTION CRC$(Txt$ AS String) 'Returns the Txt$ passed to it with "*hh" added, where hh is the NMEA Hex checksum
'The receiving station checks the checksum - if not OK it just ignores that sentence
'Local String Txt$
 Local Integer n
 Chksum = 0
 FOR n = 2 TO LEN(Txt$)  'n=2 makes it skip the leading $
   Chksum=Chksum XOR ASC(MID$(Txt$,n,1))
 NEXT n
 CRC$=Txt$+"*"+HEX$(Chksum,2)
END FUNCTION
Any comments/suggestions/questions welcome,
Cheers,
Andrew
