Local Time 17:47 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite ' Orientation ' error ? ..... Then acts like it worked ?
hitsware2
Posted: 11:59pm 29 Dec 2021
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyACM0, 15:50:40
Press CTRL-A Z for help on special keys
option reset
> option lcdpanel ssd1306spi L,gp2,gp3,gp5
Error : Orientation
> option lcdpanel ssd1306spi P,gp2,gp3,gp5
Error : Display already configured
my site
Posted: 12:37am 30 Dec 2021
Try OPTION LCDPANEL DISABLE before trying a new configuration.
disco4now
Posted: 05:09am 30 Dec 2021
comma required between controller and orientation parameter
F4 H7FotSF4xGT
Posted: 08:24am 30 Dec 2021
This needs tidying up so the LCDPANEL type is not set if the command fails verification later in the parse. Will fix in the next beta
hitsware2
Posted: 02:26pm 30 Dec 2021
  matherp said  This needs tidying up so the LCDPANEL type is not set if the command fails verification later in the parse. Will fix in the next beta
While You are tidying :
Would it make more sense for the
OPTION SYS SPI command to have
parameters ... CLK,MOSI,MISO,CS
and
OPTION LCDPANEL to have
......OR, RESET, DATA COMMAND
( move CS to the system spi since it
would better fit common parlance )
my site
Posted: 02:29pm 30 Dec 2021
  Quote  While You are tidying :
No: because there may be three CS for LCD, Touch and SDcard. CS is properly associated with the device
Edited 2021-12-31 00:30 by matherp
