Local Time 18:56 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Large Integer Array Issue
GerryL
Posted: 03:03am 28 Dec 2021
Note sure if I'm doing something wrong in assuming an integer array, DisplayLoc in program below, to be 64kb in size by declaring an array of 8000 integers but it doesn't appear to be 64kb in size. In the program below reading and writing to the 64kb array up to &HFA00 works fine but  writing to the other array, DisplayLoc, interferes with the 64kb array data above location &HFB00.  Setting the size of the 64kb to 8100 integers fixes the issue, even up to &HFFFF.
The test program is,
OPTION EXPLICIT
OPTION DEFAULT NONE
OPTION CONSOLE SERIAL
DIM AS INTEGER DisplayLoc(15,3)
DIM AS INTEGER Memory64k(8000) ' 64k data
POKE VAR Memory64k(), &HFA00, 33 ' put 33 at byte location FA00
print "BEFORE FA00 = ", PEEK(VAR Memory64k(), &HFA00)
DisplayLoc(0,0) = 200
print "AFTER FA00 = ", PEEK(VAR Memory64k(), &HFA00)
POKE VAR Memory64k(), &HFB00, 33 ' put 33 at byte location FB00
print "BEFORE FB00 = ", PEEK(VAR Memory64k(), &HFB00)
print "AFTER FB00 = ", PEEK(VAR Memory64k(), &HFB00)
The program output is,
BEFORE FA00 = 33
AFTER FA00 = 33 ' this is good
BEFORE FB00 = 33
AFTER FB00 = 200 ' this is not so good
Details are:
CMM2
Firmware Version 5.0702
Option List
CURRENT VGA mode 800x600 RGB332
CURRENT DISPLAY 50,100
OPTION USBKEYBOARD US
OPTION MOUSE 0,4
OPTION RAM ON
OPTION MAXCTRLS 100
Note that the issue is the same when using OPTION FLASH
The memory check printout below may indicate that the array is not 64k long
> memory
Program:
  1K ( 1%) Program (15 lines)
515K (99%) Free
Data:
 63K ( 1%) 2 Variables
  0K ( 0%) General
4764K (99%) Free
As mentioned I'm working around this by declaring the array to be 8100 integers so not a big issue as the CMM2 has stax of variable memory but it would be interesting to know why it does this.
Gerry
Posted: 07:27am 28 Dec 2021
The first entry in the array is 0, so when you declare an array size 8000, then it contains 8001 variables.
Posted: 08:04am 28 Dec 2021
You can, of course, use OPTION BASE 1 to start the array at element 1.
Posted: 08:30am 28 Dec 2021
Isn't &HFB00 (64256 decimal) outside the array?
Edited 2021-12-28 18:30 by JohnS
Posted: 08:47am 28 Dec 2021
An array specified as DIM a%(8000) is 64008 bytes long /1024 = 62K bytes long
An array specified as DIM b%(15,3) is 512 bytes long hence total rounded up of 63K bytes
As John says &HFB00 is well outside the limits of a% which finishes at &HFA07 so poking it will corrupt the following array
Much better to forget POKE and stick to array indicies
jirsoft
Posted: 12:51pm 28 Dec 2021
64kB array should be
DIM AS INTEGER Memory64k(8192) ' 64k data
Jiri
GerryL
Posted: 12:37am 29 Dec 2021
Thanks guys, you have set me straight, appreciate the feedback.
Gerry
