Local Time 18:56 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite strange bahaviour
wolfme
Posted: 02:55pm 15 Dec 2021
i found strange behaviour of my picomite (with V5.07.01) when changing ctrl-c to my own exit routine.
after executing
Option Break 4
On Key 3, my_exit()
For r=1 To 1000
 Print r
 Pause (1000)
Next r
Sub my_exit()
 Option Break 3
 Print "Bye..."
 End
i cannot do xmodem transfers until i reset my picomite.
What's wrong? Do i miss something?
Wolfgang
Edited 2021-12-16 00:57 by wolfme
Posted: 03:25pm 15 Dec 2021
It is a sort of a bug but sort of you not tidying up fully - thanks for the diagnostic. The workaround is to include
ON KEY 3,0
in my_exit
Edited 2021-12-16 01:26 by matherp
wolfme
Posted: 03:35pm 15 Dec 2021
  matherp said  It is a sort of a bug but sort of you not tidying up fully - thanks for the diagnostic. The workaround is to include
ON KEY 3,0
in my_exit
yes, this did the trick...
many thanks!
Wolfgang
Posted: 03:41pm 15 Dec 2021
Peter,
I had made a note to query you about this with regards implementation in MMB4L. In your opinion should OPTION BREAK be reset to 3:
- Only on NEW/RUN/LOAD ?
- On program END, either implicit or explicit ?
- On uncaught ERROR ?
- Something else ?
Posted: 03:57pm 15 Dec 2021
  Quote  I had made a note to query you about this with regards implementation in MMB4L.
In general I've just copied direct from Geoff's code
There is a big conceptual issue here
As standard MMBasic tidies up when you issue a RUN command. So after exiting a program all the stuff like variables are available for inspection. On the CMM2 there is so much going on that I implemented a subroutine that is called on any exit to tidy up everything except variables.
The issue found by Wolfgang was that the key interrupt was still active and that was "b.....ing" xmodem which unlike everything else deals with non-ascii characters.
The classic example of this issue is with GUI controls that still sort of respond after the program is stopped with ctrl-C
No easy answer I'm afraid
wolfme
Posted: 04:23pm 15 Dec 2021
For me it's absolute ok.
I've put this to my teraterm xmodem transfer macro before xmodem starts
So easy going...
Wolfgang
Posted: 04:44pm 15 Dec 2021
  matherp said  There is a big conceptual issue here...
Yes, I now remember I saw this with SETTICK interrupts still being fired after a program had exited to the BASIC prompt and ended up temporarily (?) patching over the issue by clearing all interrupts. I made a mental note that probably they should actually be "suspended" so they could be restored if the user chose to CONTINUE ... but given the existing limitations on the use of CONTINUE I wasn't sure how useful that would be. You'd also need to give special consideration as to how to handle missed SETTICK interrupts and whether to "backdate" the TIMER to when the program exited.
As you say, "No easy answer".
Thanks anyway,
wolfme
Posted: 05:07pm 15 Dec 2021
Could it add to the xmodem command itself?
something like:
- save the on key state
- execute on key 3,0
- execute xmodem transfer
- restore on key state
Wolfgang
Posted: 05:48pm 15 Dec 2021
  Quote  Could it add to the xmodem command itself?
Don't worry - trivial to fix - will be in the next beta
wolfme
Posted: 07:21pm 15 Dec 2021
