Local Time 18:56 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RoboLinux
Tinine
Posted: 07:42am 14 Dec 2021
Any idea if this is just hype?
Posted: 08:52am 14 Dec 2021
I've run Windows in VMs (not actually Stealth VM) on a linux box so it's definitely possible. I'm not sure that you'd end up with a machine that would run *all* the Windows programs on your hard disk though as not all are polite enough to use their IO properly, and VMs generally need valid system calls (or at least they used to).
It's rather cool to have two different versions of Windows running independently in different windows on your linux desktop. :)
Edited 2021-12-14 18:54 by Mixtel90
