Forum Index : Microcontroller and PC projects : Raspberry Pi Pico Board (Crowdfunding)
| Stefan Newbie Joined: 28/10/2021 Location: GermanyPosts: 4 |
Hello, what do you think of it is that is it compatible with mmbasic? greetings Stefan PI Pico Board |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9268 |
There's no direct software support for LoRa modules built into MMBasic, but from a hardware point of view it should be able to get it to work as it only needs a COM port and two or three output pins. You'd have to handle the COM port and those pins in software. Mick Zilog Inside! nascom.info for Nascom & Gemini |
