Local Time 19:59 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Two PicoMites on one PC?
Calli
Posted: 02:20pm 03 Dec 2021
Solved!
Maybe it is stupid Windows (10) but I can't connect two Picomites to one Computer via USB.
Seperately they work, but seem to share one COM-Port, which I can change, but as soon I do it for one, Windows connects the same COM Port for the other one, so when I plug in both one is not given a Port... Windows can't differentiate the boards.
EDIT: They are on the same USB-Hub. It seems it works when both are connected to a different Port/Hub on the PC... Still.. inconvenient..
EDIT EDIT: After I used them on different Ports/Hubs they suddenly work together! WINDOWS...
I leave this here, maybe it is helpfull later.
Any ideas?
Carsten
Edited 2021-12-04 00:26 by Calli
Kabron
Posted: 03:02pm 03 Dec 2021
It is also very annoying that pico constantly changes its port.
Posted: 06:22pm 03 Dec 2021
Mine doesn't seem to.
Calli
Posted: 06:27pm 03 Dec 2021
  Kabron said  It is also very annoying that pico constantly changes its port.
Can't reproduce that. It may change (close to my problem) when changing which port it is connected to.
C!
