Local Time 20:53 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Raspberry Pi Zero 2 W bootup time?
Posted: 03:20pm 25 Nov 2021
Does anyone yet have a Raspberry Pi Zero 2 W?
I'm wondering about the bootup time. With a Raspberry Pi Zero W, systemd-analyze gives me this (39.313s):
$ systemd-analyze
Startup finished in 4.497s (kernel) + 34.815s (userspace) = 39.313s
graphical.target reached after 34.481s in userspace
led-bloon
Posted: 12:38am 26 Nov 2021
Buster-Std armv7l
kernel:  5.10.63-v7+
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
Startup finished in 4.012s (kernel) + 13.572s (userspace) = 17.585s
graphical.target reached after 13.356s in userspace
Bullseye-Full armv7l
kernel:  5.10.63-v7+
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
Startup finished in 4.117s (kernel) + 19.353s (userspace) = 23.470s
graphical.target reached after 18.778s in userspace
led
edit: Confirmed hardware
Edited 2021-11-26 10:40 by led-bloon
Miss you George
Posted: 01:22am 26 Nov 2021
Thank you very much, but really? -- buster 17.585s; bullseye 23.470s. 33% increase. Talk about bloat.
scruss
Posted: 03:35am 26 Nov 2021
How often do you reboot? I'm more used to keeping the thing going than boot times, so I like the 5x speedup from the Zero.
(I've had a Zero 2 W since the Sooper Sekrit Reseller-only session in early October. Decent machine, and what they've done to stop it getting too hot is pretty marvellous.)
Posted: 03:47am 26 Nov 2021
  scruss said  How often do you reboot? I'm more used to keeping the thing going than boot times, so I like the 5x speedup from the Zero.
It's not an issue for me personally (usually--today I've been running something on a pi zero w which requires rebooting when I encounter an error--several dozen reboots today (but that's not why I asked the question)).
My question was to find out the extent to which the Pi Zero 2 W might resolve the issue for those who want their MMBasic to be "instant on" like the CMM2. I didn't expect it to reach that speed, but 17 seconds wouldn't seem too intolerable to me (nor, to me, would 23 seconds).
led-bloon
Posted: 07:12am 26 Nov 2021
Here are the figures for both Buster & Bullseye Lite versions
(which are the ones recommended for running Pi-cromite MMBasic)
Some of Bullseye figures are "strange" to say the least, and note
the "graphical.target", I had to double check it was indeed the
Lite version.
Buster-Lite armv7l
kernel:  5.10.63-v7+
Startup finished in 4.033s (kernel) + 15.376s (userspace) = 19.410s
multi-user.target reached after 15.315s in userspace
Bullseye-Lite armv7l
kernel:  5.10.63-v7+
Startup finished in 4.089s (kernel) + 21.440s (userspace) = 25.529s
graphical.target reached after 16.516s in userspace
led
PS Pi-cromite runs quite well on both versions although not fully tested!
Edit: Peter named his MMBasic port Pi-cromite not Picromite (but I'm a lazy
two-fingered typer, like so many others). I've corrected anyway.
Edited 2021-11-26 18:27 by led-bloon
Miss you George
Posted: 01:37pm 26 Nov 2021
Odd that the "lite" version takes longer than the non-lite.
  led-bloon said  PS Pi-cromite runs quite well on both versions although not fully tested!
That would be great. Did you test pin control? As I recall, that was the problem the last time I looked--pigpio acting up.
Calli
Posted: 04:42pm 26 Nov 2021
There is a project to boot a Pi3(!) in less than 2 seconds:
https://furkantokac.com/rpi3-fast-boot-less-than-2-seconds/
led-bloon
Posted: 03:42am 27 Nov 2021
  Quote  PS Pi-cromite runs quite well on both versions although not fully tested!
My apologies, the above is an over-simplification of the software performance.
I got a command prompt. I ran speedtest.bas ok. From memory, that's about it.
The Zero 2 is for the collection, and not for any general use, hence no GPIO
pin-headers soldered.  I was more directed to the fact that it ran on Bullseye ok.
led
Miss you George
