Local Time 20:52 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How do you compose MOD music for the CMM2?
danielkos
Posted: 06:01am 22 Nov 2021
Sorry if there's already a thread on this. I couldn't find one.
Posted: 07:32am 22 Nov 2021
No idea. Tell us. :)
MMBasic can play them using PLAY MODFILE and PLAY MODSAMPLE, but I'm not aware of a MOD file composer for MMBasic.
Posted: 08:13am 22 Nov 2021
I used to use Soundtracker, NoiseTracker Octamed etc. back in my Amiga days.
Install WinUAE (or other emulator) and snag that code. Should be up an running in 10-20 mins (but the supplied samples are a bit "dated" so you'll spend longer finding nice ones - plenty of libraries about)
to whet your appetite https://www.youtube.com/watch?v=0fGsVs0o4As (warning: total shoite content, unless you are a 90s raver)
Edited 2021-11-22 18:20 by CaptainBoing
paceman
Posted: 11:12am 22 Nov 2021
Try this this link Daniel. There's also a full archive of mod files here.
Greg
vegipete
Posted: 05:47pm 22 Nov 2021
Making MOD files
The above helps with embedding sounds in a MOD file. OpenMPT can be used for composing too. A MIDI to MOD program would be quite useful - then you could play your digital piano and directly generate MOD files. This is all software on the PC side of things though, not running on a CMM2.
Edited 2021-11-23 03:53 by vegipete
